Rear Subframe Repair
102 replies to this topic
#76 gaspen
gaspen
  • 942 posts
Posted 24 March 2020 - 07:17 PM
I voted to plan A  :P
This week I have more time to work on the subframe, every day allow me a little step forward. I'll get back the radius arms from the machine shop tomorrow and I am very excited how they will fit.
Today I came up with these supports for the radius arm pivot. The washer and the sleeve will be welded to one piece of course and I will cut it for the correct length.
Attached File  IMG_20200324_174702.jpg   72.21K   0 downloads
Attached File  IMG_20200324_174555_1.jpg   73.12K   0 downloads
#77 gaspen
gaspen
  • 942 posts
Posted 28 March 2020 - 06:31 PM
Update from today. The stiffener - or what they call it - is welded into its place.
Please note the Anti Rotation Device at the brake hose - I made it from a plain washer  :shifty:
Attached File  IMG_20200328_165826_1.jpg   90.03K   0 downloads
Attached File  IMG_20200328_174650.jpg   56.33K   0 downloads
Attached File  IMG_20200328_174615.jpg   30.64K   0 downloads
Attached File  IMG_20200328_174639.jpg   34.75K   0 downloads
#78 MacGyver
MacGyver
  • 1,027 posts
Posted 28 March 2020 - 06:45 PM
Nice straight spot welding there! ?
Looks nice and sturdy.
Finished stripping mine down today, will start the mods next week, but won't be as nice as this one I'm sure.
#79 gaspen
gaspen
  • 942 posts
Posted 29 March 2020 - 05:08 AM
If you can imagine, you can do it ! Just take your time.
And share your progress, I am curious !
#80 MacGyver
MacGyver
  • 1,027 posts
Posted 29 March 2020 - 07:55 AM
I will! ? I said I would.
Its just I have too much imagination and not enough time... ?
#81 gaspen
gaspen
  • 942 posts
Posted 29 March 2020 - 10:47 AM
Next problem to solve : the radius arm pivot has a grease nipple, as you know. On that end the thread is longer on the pivot. If I insert the shorter thread inside then only the half of the nut will crew on the pivot. I have to figure out how to bend the brake pipe to allow the acces to the nipple. Maybe I should put a 45-degree nipple ?!
Attached File  IMG_20200329_095443.jpg   55.54K   0 downloads
Attached File  IMG_20200329_115211.jpg   40.98K   1 downloads
Attached File  IMG_20200329_104445.jpg   41.39K   1 downloads
#82 gaspen
gaspen
  • 942 posts
Posted 30 March 2020 - 03:02 PM
Almost finished :) Most of the welding is done on the left side.
Attached File  IMG_20200330_135843.jpg   65.38K   2 downloads
Attached File  IMG_20200330_140223.jpg   82.07K   2 downloads
#83 sonscar
sonscar
  • 2,997 posts
Posted 30 March 2020 - 05:57 PM
Great work,Steve..
#84 gaspen
gaspen
  • 942 posts
Posted 31 March 2020 - 10:57 AM
Now the subframe is in one piece  :shades: I will make some weld for reinforcement before it goes to galvanising.
Attached File  IMG_20200331_121042.jpg   81.85K   6 downloads
#85 gaspen
gaspen
  • 942 posts
Posted 31 March 2020 - 12:15 PM
Radius arm and hi-lo fitted for checking. A little adjustment needed at the support bowl of the rubber cone. I adjusted it with a hammer.
Attached File  IMG_20200331_135852.jpg   66.67K   1 downloads
#86 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 31 March 2020 - 12:30 PM
Proper engineering!
#87 MacGyver
MacGyver
  • 1,027 posts
Posted 31 March 2020 - 05:53 PM
Well that's what I call a piece of art!
#88 DamoMini
DamoMini
  • 40 posts
Posted 31 March 2020 - 09:10 PM
Wonderful work - so jealous of those skills!
#89 gaspen
gaspen
  • 942 posts
Posted 01 April 2020 - 05:11 PM
I made some seam weld for reinforcement on the bottom strap. Should I weld it on the top also ?
Attached File  IMG_20200401_120743_1.jpg   45.64K   0 downloads
And the inner thread of the pivot. The end with the nipple is longer, maybe I'll need a 45 or 90 degree nipple.
Attached File  IMG_20200401_093045.jpg   38.5K   0 downloads
Edited by gaspen, 01 April 2020 - 05:16 PM.
#90 gaspen
gaspen
  • 942 posts
Posted 12 April 2020 - 06:06 AM
Some final touch before galvanizing
I've made a bracket for the brake valve
Attached File  IMG_20200409_175334.jpg   78.61K   0 downloads
...and bent the brake tubes. Maybe I should route the left side under the exhaust hanger.
Attached File  92575469_2570898843151923_2265735140019798016_n.jpg   32.93K   0 downloads
The grease nipple must be inside and with a 45-degree nipple I can access it.
Attached File  IMG_20200410_094017.jpg   65.96K   0 downloads
I drilled a hole on the bottom to help drain the water or moisture. The "gutter" prevents the dirt from entering from the front. I don't know if it will work or not, but that was the most corroded part of the front cross beam.
Attached File  IMG_20200410_122321_1.jpg   39.77K   0 downloads
