Rear Subframe Repair
102 replies to this topic
#61 gaspen
gaspen
  • 942 posts
Posted 17 March 2020 - 11:49 AM
Let's go in serious now !
Outer beam fitted. I am using the old pivot for keep the distance
Attached File  IMG_20200317_092018.jpg   67.25K   4 downloads
Attached File  IMG_20200317_092707_1.jpg   43.12K   4 downloads
Four attachment point is screwed into its place. The longitudinal distance of the holes are right.
Rear crossmember fitted with pliers temoprarily as I have to insert the inner beams also if everything is ready.
Attached File  IMG_20200317_110716.jpg   61.06K   4 downloads
A little adjustment will need transversely.
Attached File  IMG_20200317_110922.jpg   58.26K   2 downloads
#62 gaspen
gaspen
  • 942 posts
Posted 18 March 2020 - 06:55 PM
Today I started the final welding  and also I said goodbye to the old panels  :shy:
Attached File  IMG_20200318_111048.jpg   57.12K   3 downloadsAttached File  IMG_20200318_105950.jpg   41.99K   3 downloadsAttached File  IMG_20200318_105958.jpg   37.36K   1 downloadsAttached File  IMG_20200318_111519.jpg   36.68K   1 downloadsAttached File  IMG_20200318_114431.jpg   41.04K   2 downloads
#63 Homersimpson
Homersimpson
  • 829 posts
Posted 18 March 2020 - 07:59 PM
That is excellent work and very much food for thought, especially with the price of rear subframes.
I was always told that you can't weld rear subframes by my MOT man and just took it at face value but in reality there is no reason you can't if you do it to this standard.
#64 sonscar
sonscar
  • 2,997 posts
Posted 18 March 2020 - 10:21 PM
You are allowed to repair welded subframes by welding,the criteria being"does it appear to be as strong as the original?"Cast or forged items should not be welded.Steve..
#65 gaspen
gaspen
  • 942 posts
Posted 19 March 2020 - 06:59 AM
Is there cast or forged parts in the subframe ? I didn't find any.
Edited by gaspen, 19 March 2020 - 06:59 AM.
#66 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 19 March 2020 - 07:37 AM
I think sonscar just mentioned that for general purposes?
Like if you habe a rear radius arm broken, then you can't weld it.
Anyway, welding cast or forged parts is another piece of cake as sheet metal.
Very nice job by the way gaspen!!
#67 gaspen
gaspen
  • 942 posts
Posted 19 March 2020 - 01:10 PM
I think if I follow the rules of welding, I will be successful. I hope at least  :proud:
#68 gaspen
gaspen
  • 942 posts
Posted 22 March 2020 - 06:38 PM
Note that hi-tech checkin tool  :proud: Anyway it points to radius arm.
Attached File  IMG_20200315_170616.jpg   46.07K   2 downloads
A test fit again before I continue welding.
Attached File  IMG_20200322_140617.jpg   55.35K   2 downloads
I will use a sleeve instead of a bush for holding the radius arm pivot. The triangle part will be re-manufactured
Attached File  IMG_20200322_170235.jpg   69.85K   2 downloads
#69 gaspen
gaspen
  • 942 posts
Posted 23 March 2020 - 06:20 PM
I'd like to ask some advice from the helpful readers.
Somewhere in 1975 at the end of a hard working day Pedro wasn't able to target the spot welder evenly. The front crossmember looks like a shooting gallery after a I drilled the spots.
Plan A : welding the holes, re-drill them even distance, the welding the insert back
Plan B : leave it as it is now and using the unevenly holes
Attached File  IMG_20200323_172047.jpg   35.4K   1 downloads
And some pics about the process :
Attached File  IMG_20200323_174759.jpg   64.13K   1 downloads
Attached File  IMG_20200323_174949.jpg   60.93K   0 downloads
Attached File  IMG_20200323_174748.jpg   77.49K   0 downloads
#70 MacGyver
MacGyver
  • 1,027 posts
Posted 23 March 2020 - 06:40 PM
Personally would make them all align on the same line, but that's just because I'm picky... ?
If you weld it all up, you can chose to spot weld if you'd like too. Would make it cleaner I think.
Ben
#71 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 23 March 2020 - 06:41 PM
Somewhere in 1975 at the end of a hard working day Pedro wasn't able to target the spot welder evenly. The front crossmember looks like a shooting gallery after  I drilled the spots.
B if you can live with it?
By the time it's Zinc primered, stone-chip resistant coated and bolted underneath the car, who's going to know?
#72 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 23 March 2020 - 06:57 PM
If like mentioned you are picky then even them up, but once welded up you wont see them so ignore and carry on.
#73 gaspen
gaspen
  • 942 posts
Posted 23 March 2020 - 07:52 PM
Me !
#74 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 23 March 2020 - 07:55 PM
Me !
But can you live with/get over it?
If not, the A's the way.
#75 Homersimpson
Homersimpson
  • 829 posts
Posted 23 March 2020 - 08:53 PM
Definatly B, once welded up and ground back you won't see them anyway and the spot welding on most cars is uneven to some degree, they weren't built by computer controlled robots so some variation was inevitable.
