Rear Subframe Repair
102 replies to this topic
#46 gaspen
gaspen
  • 942 posts
Posted 22 February 2020 - 06:02 PM
A little process today. I am not sure that the spot-welded, cone-shaped support will be strong enough.
 Naturally there will be more spots when finished. I just don't want to drill 10 spots if I f@ck up  :D
What's your opinion ?
Attached File  IMG_20200222_162157.jpg   68.12K   3 downloadsAttached File  IMG_20200222_175322.jpg   34.41K   2 downloadsAttached File  IMG_20200222_162211.jpg   65.25K   0 downloads
#47 sonscar
sonscar
  • 2,997 posts
Posted 22 February 2020 - 07:17 PM
Excellent work,the cones will be plenty strong enough,the shape gives the strength.Steve..
#48 greenwheels
greenwheels
  • 687 posts
  • Local Club: Mini Fixers
Posted 23 February 2020 - 11:15 AM
Spots look good.
Do a test piece on a couple of scrap pieces and then try to force them apart with a hammer and cold chisel. It should be difficult to part them.If you hammer hard and long enough they will come apart but so long as the centre weld stays intact on one piece you're OK.
#49 MacGyver
MacGyver
  • 1,027 posts
Posted 23 February 2020 - 05:05 PM
As above, but if you take the two welded test pieces and hold one-piece in the vice you can use a pair of pliers to pull it apart. If you have a hole on one of them, you're golden. ?Attached File  _20200223_180329.JPG   32.85K   1 downloads
You should have a 4mm pip after ripping to have a strong weld.
#50 gaspen
gaspen
  • 942 posts
Posted 23 February 2020 - 06:51 PM
I was so immersed in the work that I just welded and welded  :D I hope it will be strong enough, but tomorrow I do the test in the vice.
Attached File  IMG_20200223_134216.jpg   73.6K   4 downloads
Attached File  IMG_20200223_194406.jpg   88.84K   3 downloads
Attached File  IMG_20200223_174519.jpg   37.46K   2 downloads
This happens when an old piece become a template  :proud:
Attached File  IMG_20200223_110657.jpg   87.11K   5 downloads
#51 gaspen
gaspen
  • 942 posts
Posted 04 March 2020 - 11:49 AM
Hello, please help me a little bit
Is this the correct orientation of the rear mount ? I mean the thick part is at the back and the thin is forward.
The hole of the bushes is NOT on the middle.
(Not mine subframe pictured)
Attached File  Rear-Subframe-Rebuilt.jpg   56.46K   9 downloads
#52 MacGyver
MacGyver
  • 1,027 posts
Posted 04 March 2020 - 12:10 PM
I belive those are the wrong way round.
Someone will confirm in a minute...
#53 MacGyver
MacGyver
  • 1,027 posts
Posted 04 March 2020 - 12:13 PM
On my old mini they are this way too, just had a look, but it might be wrong as I built it 20years ago with no clue. ?Attached File  image.gif   43.18K   3 downloads
Edited by MacGyver, 04 March 2020 - 04:35 PM.
#54 Homersimpson
Homersimpson
  • 829 posts
Posted 04 March 2020 - 02:51 PM
Looks right to me.
#55 imack
imack
  • 2,106 posts
Posted 04 March 2020 - 06:08 PM
Mine are as per your photograph.
Edited by imack, 04 March 2020 - 06:09 PM.
#56 gaspen
gaspen
  • 942 posts
Posted 05 March 2020 - 11:22 AM
Thank guys ! Now it fits better  :shifty:
Started to assembly the parts. I think I have to purchase more pliers  :lol:
Attached File  IMG_20200305_095911.jpg   57.76K   2 downloads
#57 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 05 March 2020 - 04:07 PM
Although the spot welds look good i would seam weld there as well. Lots of forces transmitted there so seam welding will ensure you have maximum strength.
#58 gaspen
gaspen
  • 942 posts
Posted 05 March 2020 - 05:20 PM
I think that I'll seam weld only that cone. Unfortunately the aligment of the cone support bowl on which the rubber cone seats is not so good.
I also thought that I cut the cones from the old pieces and weld them to the new beams, but there is too much rust. So I reject this idea.
Edited by gaspen, 05 March 2020 - 05:21 PM.
#59 gaspen
gaspen
  • 942 posts
Posted 12 March 2020 - 05:02 PM
Cones are almost finished. Some griding is needed.
Attached File  IMG_20200312_173202_1.jpg   69.2K   3 downloads
#60 gaspen
gaspen
  • 942 posts
Posted 15 March 2020 - 11:23 AM
Cone welding and grinding is finished now on all 4 beams.
Attached File  IMG_20200314_123248.jpg   65.06K   0 downloads
I had more ideas about the rim of the support and finally I made this piece :
Attached File  IMG_20200315_114038.jpg   20.34K   0 downloads
It fits like this. The arched flange will be seam welded to the cone.
Attached File  IMG_20200315_114054_1.jpg   65.73K   0 downloads
The heel fits to the other side and it will be spot welded
Attached File  IMG_20200315_114058_1.jpg   66.17K   1 downloads
