1997 Mpi Cooper - Full Restoration @classic & Sport
29 replies to this topic
#16 Classic & Sport
Classic & Sport
  • 33 posts
Posted 25 June 2020 - 02:09 PM
More done
Full scuttle panel / windscreen surround
gone for the full height panel due to rust high up the a pillars, caused by the foam stuffed into the roof corners at the factory and wrapped around the aerial lead, which has become damp over time and rotted the panel from the inside out
fZ4e21B.jpg?1
Top dash rail fitted at the same time so all 3 sections (scuttle, bulkhead and dash rail) could be spot welded together
Then Finally the shell was removed from the jig to carry on
Passenger side rear arch / 1/4 panel next
sill stiffener and closing panel fitted
Then rear quarter
one side down, one to go!
same again...
couple of brackets to transfer over...
and quarter panel fitted
Lower dash rail next and I started by spot welding the rail and shelf together off the car
I then turned to replacing the inner a post panels, for some reason the mountings for the lower dash rail had not been fitted to the passenger side so I had to make some following the drivers side for shape (remembering to reverse the shape of course to fit passenger side!)
and then finally fitting the dash rail
Slight break from the shell next and on to the doors, at first glance they dont look too bad, indeed the outer skin is rust free but looking closer they have been repaired in the past using magnum skins, the frames have also rusted in other places not covered in the past repair so skins and frame repairs it is...
#17 minipickup
minipickup
  • 74 posts
Posted 25 June 2020 - 09:11 PM
Looking good, that is a serious amount of work but it is starting to take shape.
#18 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 25 June 2020 - 10:46 PM
Impressive stuff, it is really taking shape now.
#19 johnR
johnR
  • 2,297 posts
Posted 26 June 2020 - 01:06 PM
A more faint-hearted person would have walked away from that car - well done for taking it on! What plans for the engine?
#20 Wizzalong
Wizzalong
  • 100 posts
Posted 08 July 2020 - 08:58 PM
A pleasure to see perfectionism, May I ask which spot welder do you have? and did your floor come with the studs?
#21 andysspanners
andysspanners
  • 18 posts
Posted 09 July 2020 - 10:08 AM
Some really great work here. Fantastic to see
#22 Classic & Sport
Classic & Sport
  • 33 posts
Posted 16 November 2020 - 04:02 PM
Standard mpi 1275cc im afraid, nothing exciting!
#23 Classic & Sport
Classic & Sport
  • 33 posts
Posted 16 November 2020 - 04:07 PM
Thank you, my spot welder is a Tecna 3484
My floor didn't come fitted with studs, I've had to add them myself, I have not been able to find the coarse thread studs used at the factory but have found that a standard M5 is close enough, I have trial fitted the fuel lines and they bolt up and grip nice and tight on the m5's so I'm happy with that
#24 Classic & Sport
Classic & Sport
  • 33 posts
Posted 16 November 2020 - 04:12 PM
Been a while since an update, my apologies, big one coming soon!
for now the welding is finished and I've moved on to paint prep, first up is underneath / arches while its still on the spit but I will do a full update when I have more
Ryan
#25 nitrodave
nitrodave
  • 44 posts
Posted 16 November 2020 - 06:15 PM
great work! Really enjoy your updates and look forward to seeing more
#26 gaspen
gaspen
  • 942 posts
Posted 17 November 2020 - 06:38 AM
Hello.
Did you removed the E-coat from the floor panels or what I see is the primer ?
#27 Classic & Sport
Classic & Sport
  • 33 posts
Posted 26 November 2020 - 08:42 AM
Hello.
Most of the E - coat removed, probably 80% bare metal, between what was removed for welding and then flatting out any remaining dodgy looking areas it doesnt leave a lot!
#28 Classic & Sport
Classic & Sport
  • 33 posts
Posted 26 November 2020 - 08:48 AM
Quick update
After prepping the underside in my previous post it was wheeled straight into the booth and given a good coat of epoxy primer
Next Day I sealed up all seams using a pu sealant
And when that was cured I went over the top of the same seams with a rubberised spray sealant for extra protection and that factory look
And then finally 2 coats of Novol Cobra 2k truck bed liner (similar to upol raptor but slightly cheaper, just as good and more importantly a lot easier to tint)
Ryan
#29 surfblue
surfblue
  • 1,827 posts
Posted 26 November 2020 - 05:51 PM
Lovely work, would love to have the ability to repair a shell to that standard although as you say a brand new heritage shell would probably have been the best bet!
Keep the updates coming, loving this project.
#30 Blake71
Blake71
  • Just Joined
  • 82 posts
Posted 03 December 2020 - 09:04 AM
Inspirational stuff, great work.
