Lower Quarter Repair Panel
18 replies to this topic
#16 Wreckitralph1
Wreckitralph1
    Formally known as wreckitralph
  • 127 posts
Posted 12 January 2020 - 11:46 AM
if the heel board is sound ad will clean back to good steel i would leave it for me it was by far the worst panel i had to change with getting it lined up even with a subframe bolted to it the inner wings were a peice of cake even the bulkhead panel was easy by using the shock mounting holes in the bulkhead x member to locate to the inner wings and door pillars but the heelboard took loads of messing with to get it right  another thing i would say is  i started at the front and worked back your right with starting at the rear and going forward  thats how i would do it next time
Edited by Wreckitralph1, 12 January 2020 - 11:50 AM.
#17 sc-em
sc-em
  • 206 posts
Posted 14 January 2020 - 07:28 PM
As a matter of interest, what thickness of steel are you using for general patching/plating. 1mm or 1.2mm. Just so I can get some plate for the same purpose.
#18 Wreckitralph1
Wreckitralph1
  • 127 posts
Posted 17 January 2020 - 01:30 AM
0.9-1mm for extenal panels  1.2-1.5 mm for toeboard heelboard  door posts ect is the norm i have got a set of full floors here made from 1.2 that  my good mate sorted for me and  ive just made full  inner cills from 1.2mm steel cant see a down side to using slightly thicker steel to be honest [not on outer panels]  on floors ect especially if you can press beat or swage strengthening ribs into them
Edited by Wreckitralph1, 17 January 2020 - 01:35 AM.
#19 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 18 January 2020 - 09:51 PM
Hello both,
I took today a little time to do the measurments on my car.
General view of the rear quarters:
Measurements of the closer panel
With the bit of the floor I could dug from my metal bin:
The other side is similar but here I could not find the floor bit. Sorry.
I hope this helps.
If you need other pictures or measurements please tell me before tomorrow mid-afternoon. I will then be able to do these.
Gilles
