Is Colortune Plug A Useful Aid?
Posted 08 January 2020 - 11:55 AM
Any one used a colortune plug as an aid to get the mixture correct? I'm new to engines and carburettors and struggling a bit to get my ears accustomed to the sounds of exhaust and engine noises.
Posted 08 January 2020 - 12:26 PM
does help if you have no clue what is right/wrong. Once you learn a mini you get a feeling for the idle. It does kind of help for higher rpms just to get a sense of whats going on inside but its a different story checking your mixture at high rpms whilst driving or stand still :/
If youre new to it, id get one. You learn a bit and it helps you develop your mini-senses ;)
Posted 08 January 2020 - 01:17 PM
ive had a colourtune for years bought in the seventies ,still going strong ,a usefull piece of kit
Posted 08 January 2020 - 02:43 PM
Colourtune can't lie to you.
Posted 08 January 2020 - 02:49 PM
Getting the mixture correct, having fitted a supercharger is not straightforward.
I find a colourtune most useful.
I insert the coulortune in number 4 plug, remove the bonnet and fix a shaving mirror in such a way that I can observe the coulortune while driving at night under a veriety of conditions, and while stationary, I can adjust the carb setting as indicated.
Posted 08 January 2020 - 02:50 PM
Unless you are colour blind.
Posted 08 January 2020 - 03:22 PM
oh jesus thats an idea worth tryng.... hmmmmmmmmmmmm ill have to try that one when my minis back on the road!
isnt it bad to drive with it for an extended period of time?
Posted 08 January 2020 - 03:41 PM
Better to get or rig up an AFR meter if you can
Posted 08 January 2020 - 06:46 PM
I have one and it is good - to a point.
It will help you set your mixture at idle speeds, but if your engine has been modified in any way, it will first need a rolling road session to get the correct profile needle and spring sorted, otherwise, using a Colourtune will only set the right mixture at idle and could be anywhere in the spectrum when driving.
David Vizard did do a write up many many many years back in one of the magazines with a method of running the car on stands and using the brakes to apply load, kind of a poor mans Dyno (Rolling Road), with a maximum RPM limit of 5000 rpms (beyond which, he felt the Colourtune may melt I think) and having an assistant read the Colourtune up and down the rev range while loaded.. If you were to do this, I would strongly recommend removing the wheels first, just in case the car comes off the stands ! Though, frankly I don't recommend the method as it's pretty dangerous.
You could do a similar method more safely these days with an AFR Meter and for that matter, even do that out on the road.
Posted 08 January 2020 - 07:07 PM
That'll be your eyes lying, not the Colortune.
Posted 08 January 2020 - 07:24 PM
Posted 09 January 2020 - 12:38 AM
You can get the weld in bung halfway along the exhaust if you want - and if you want to check the idle mixture too
Led doesn’t show up on the camera very well, but this was 13.9:1
Posted 09 January 2020 - 01:02 AM
Posted 09 January 2020 - 07:40 AM
When I use them I instal two on a single carb engine. There is the tendency that the outer cylinders run a bit fatter than the inner. And with two plugs you can juggle a little to get the more or less accurate mix which is always a compromise. Next step is driving under load; then a fuel/air sensor like the k&n sensor with an in-car display comes into play. But that means that you drill the exhaust and fit a M18x1 adaptor for the sensor with a line to the display.
Edited by r.tec, 09 January 2020 - 07:40 AM.
Posted 09 January 2020 - 01:44 PM
If internal combustion engines weren't on the brink of becoming history it could be worth somebody developing an electronic "smart sparkplug" along the lines of colortune - we have cheap watches that bounce a light in to your wrist to determine your blood oxygen levels so doing similar shouldn't be impossible.
