Mechanical Fuel Pump Genuine Or Non-Genuine
engine
Best Answer unburntfuelinthemorning , 31 December 2019 - 09:57 PM
I had loads of problems with this non genuine Minispares fuel pump.  Couldn't get it to sit on the cam eccentric properly and decided I didn't like the material on the arm which contacts the camshaft either.  I used a good secondhand SU pump in the end which is probably thirty five years old and that works well.  Will probably fit electric eventually.
Go to the full post
5 replies to this topic
#1 Theo
Theo
    Starting My Mini Up
  • 4 posts
Posted 31 December 2019 - 06:42 PM
Are non-genuine fuel pumps any good?
#2 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 31 December 2019 - 06:43 PM
I use whatever my local factors can supply
#3 unburntfuelinthemorning
  • 1,982 posts
Posted 31 December 2019 - 09:57 PM   Best Answer
#4 leyland73
leyland73
  • 158 posts
Posted 01 January 2020 - 09:14 AM
With the ball ache of a job to replace a mechanical pump with the engine in the car a genuine pump is the way to go. Burlen/su genuine pumps are now produced with an ethanol resistant diaphragm. We know what ethanol does to rubber fuel lines so a upgraded pump makes sense. Replaced the original pump on my Thirty last year with a new su pump.
Edited by leyland73, 01 January 2020 - 09:47 AM.
#5 unburntfuelinthemorning
  • 1,982 posts
Posted 01 January 2020 - 09:34 AM
With this in mind I should probably replace my old pump sooner rather than later.
#6 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 01 January 2020 - 01:09 PM
Yes a mechanical pump is a pain to change, especially with an LCB type exhaust however they are alot safer than how some people wire in electronic pumps.
Mechanical all the way for me
