Roller Bearing Removal
Best Answer Spider , 23 December 2019 - 03:17 AM
Moke spider, do you mean using an adapter on the end of the 1st motion shaft? Any ideas why the 1st motion shaft isn’t coming out with the bearing?
Like this ;-
The Bearings are normally quite a firm (very firm) fit on the shaft. While not something I've come across, if the Bearing is moving and the shaft is stationary then all I can think of the Nose Bearing between the 1st and Main Shaft is somehow jammed up.
Go to the full post
9 replies to this topic
#1 cjdillonnz
cjdillonnz
  • 67 posts
Posted 22 December 2019 - 05:08 AM
Hey guys,
Trying to remove the roller bearing from gearbox. I've done this before but I've installed a new RHP and now disassembling as I couldn't shift 3rd and 4th gear. I've managed to move it about 5mm and I understand the first motion shaft should come with it but it's not. What am I doing wrong? Yes I've removed the circlip. Thanks.
#2 Spider
  • 14,821 posts
Posted 22 December 2019 - 07:56 AM
Have you removed the Laygear ?
#3 cjdillonnz
cjdillonnz
  • 67 posts
Posted 22 December 2019 - 08:27 AM
Yes. It’s just the mainshaft assembly still inside.
#4 DeadSquare
DeadSquare
  • 3,089 posts
Posted 22 December 2019 - 09:13 AM
Put it out all morning in the mid day sun and try at about 1.30pm.  Al expands more than Fe
#5 Spider
  • 14,821 posts
Posted 22 December 2019 - 09:47 AM
If it's not coming out square, it can 'hook up' on the case. I use an adaptor and slide hammer.
#6 cjdillonnz
cjdillonnz
  • 67 posts
Posted 22 December 2019 - 06:53 PM
#7 floormanager
floormanager
  • 681 posts
  • Local Club: Mini Club Sussex
Posted 22 December 2019 - 07:57 PM
I've had this too, struggled for ages until I realised it was not square and locked in the housing.  Knock it back in (yes I know) and try again by ensuring you hit it square (change your position on the bearing).  I wish I could make up an adapter and use a slide hammer.  Need to buy a welder!!
#8 Spider
  • 14,821 posts
Posted 23 December 2019 - 03:17 AM   Best Answer
Like this ;-
#9 cjdillonnz
cjdillonnz
  • 67 posts
Posted 23 December 2019 - 05:02 AM
Ok thanks guys. I’ll give it a go.
#10 cjdillonnz
cjdillonnz
  • 67 posts
Posted 29 December 2019 - 03:32 AM
Thanks moke. I used a slide hammer. Two yanks and was out.
