Tach Fitting
10 replies to this topic
#1 dangreen
dangreen
  • 93 posts
Posted 08 December 2019 - 02:23 PM
Recently purchased a Jaeger 4cl rvi tach for negative earth off eBay but am unsure as to how to wire it in. It has two white wires coming off the back along with the wire for the bulb and one spade connector.
Any help would be appreciated,
Dan
Edited by dangreen, 10 December 2019 - 03:10 PM.
#2 nicklouse
  • 18,396 posts
Posted 08 December 2019 - 04:49 PM
any goodhttp://www.theminifo...i-tacho-fitting
#3 dangreen
dangreen
  • 93 posts
Posted 09 December 2019 - 02:37 PM
Found that but mine has no screw terminals. I'll see if I can upload a picture
#4 panky
panky
  • 1,785 posts
Posted 09 December 2019 - 03:19 PM
Anything like this?
#5 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 09 December 2019 - 05:03 PM
Looks like the Smiths tacho in the pic above is set up for positive ground?
#6 dangreen
dangreen
  • 93 posts
Posted 10 December 2019 - 03:12 PM
Anything like this?
Little bit like the yazaki one. I've managed to upload a picture of the back now
#7 nicklouse
  • 18,396 posts
Posted 10 December 2019 - 03:23 PM
looks more like the smiths.
terminal to the right of your wires
but give the back a good clean and you may find some marks.
what number is on the front?
#8 nicklouse
  • 18,396 posts
Posted 10 December 2019 - 03:39 PM
is it the same as this
https://mgaguru.com/...tric/et202c.htm
#9 sonscar
sonscar
  • 2,932 posts
Posted 10 December 2019 - 03:47 PM
The white wire with the loop on it operates the tach.It connects from the coil feed wire around the loop and back to the coil.It carries the current to the coil and makes the tach work via the loop.You have to remove whatever wire currently is on the coil and fit this in series.It is like the one which was fitted to my MGB.It could easily be positive earth as mine was,it may say on the face.Steve..
#10 dangreen
dangreen
  • 93 posts
Posted 11 December 2019 - 06:59 PM
Looks very similar but mine isn't smiths. Going to give it a go in series and see if that works but won't be able to for a week or so. I'll update this thread if it works
#11 dangreen
dangreen
  • 93 posts
Posted 11 December 2019 - 07:01 PM
Cheers I'll give it a go and update this if it works. It does say negative earth on it and my car is negative earth so should be ok
