1275 Engine Specifications
7 replies to this topic
#1 DavieW
DavieW
  • 22 posts
Posted 07 December 2019 - 01:48 AM
I know there are different outputs from the 1275 as per Retrominisltd page
1275cc  A+ Spec
50bhp @ 5000rpm    66lb ft @ 2600rpm    1992-2000: Mini Sprite / Mayfair
61bhp @ 5550rpm    61lb ft @ 3000rpm    1990-91: Mini Cooper
63bhp @ 5700rpm    70lb ft @ 3900rpm    1991-1996: Mini Cooper 1.3i / Cabriolet
63bhp @ 5500rpm    70lb ft @ 3000rpm    1997-2000: Mini Cooper 1.3i (MPi)
72bhp @ 6000rpm    73lb ft @ 4000rpm    1982-89: MG Metro
77bhp @ 5800rpm    80lb ft @ 3000rpm    1991-2000: Mini Cooper S 1.3i
78bhp @ 6000rpm    78lb ft @ 3250rpm    1990-91: Mini Cooper S
What are the differences that change the outputs - camshafts?, heads?, carbs?
#2 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 07 December 2019 - 07:10 AM
I'd say combination of all of the above, plus piston compression ratios, as well. I'm not sure if the final drive will also have an effect on output power or not...
#3 mini13
mini13
  • 3,810 posts
Posted 07 December 2019 - 08:27 AM
And exhausts, and some are injection,
Heads were all the same in those listed there except the mg metro and Cooper S.
Also final drive won't affect the power output
#4 minitman
minitman
  • 74 posts
Posted 07 December 2019 - 10:29 AM
Everything.
All of the components make a little more difference. From major elements like cams, cranks and pistons, to little things like polishing the head and inlet manifold surfaces, needle sizes in the carbs, and even air filters.
The correct sized carb, a stage one kit, and correct exhaust will give better through flow, and a bigger bang. Match this with opening and balancing your ports and enlarged valves, and you can transform the performance of any car.
The trick is to choose what you want to get, and then research how to get there. the rest is time effort and money.
Best of luck. I hope you get what you are after.
Minitman.
#5 nicklouse
  • 18,577 posts
Posted 07 December 2019 - 10:39 AM
And the difference now could be just about nothing in regards output.
#6 DeadSquare
DeadSquare
  • 3,089 posts
Posted 07 December 2019 - 11:19 AM
1275cc  A+ Spec
Probably nothing more than ticking EU boxes.
#7 DavieW
DavieW
  • 22 posts
Posted 07 December 2019 - 11:50 AM
Thanks for the replies guys - I know about modifying engines to produce more power. I maybe didn't explain clearly in my original post - what I meant was what differences was there from the factory to produce the various power outputs? In particular for the first 2 in the list between the Sprite/Mayfair and the Cooper.
#8 malc_west
malc_west
  • 241 posts
Posted 07 December 2019 - 02:45 PM
1275cc A+ Spec
So if mines got twin hs2 carbs on a metro engine it should be around 70bhp?
