Base Coat To Raptor Ratio
5 replies to this topic
#1 mattmiglia
mattmiglia
  • 515 posts
Posted 04 December 2019 - 03:18 PM
I’ve seen and read it uses between 3-4 bottles of Raptor to do the underside but what amount of base coat have people used to tint it?
#2 Painter man
Painter man
  • 86 posts
Posted 04 December 2019 - 06:29 PM
Hi mate it’s craig who came and collected the mirror off you I use raptor at work all the time did you know you can buy it pre mixed to your ral colour then you just add the harder give it a shake and spray on I can pass you on the reps number if you want
#3 mattmiglia
mattmiglia
  • 515 posts
Posted 04 December 2019 - 09:31 PM
I’ve already got the stuff mate just need to get base coat but cheers
#4 danny79
danny79
  • Just Joined
  • 111 posts
Posted 05 December 2019 - 12:19 AM
from the TDS
For best results, use solvent based acrylic basecoat toners (ask your paint supplier to leave out the binders). NOTE: Acrylic basecoat toners tend to have high color strength so use sparingly (less than 10% tint by volume). RAPTOR is compatible with any urethane based color, including 2K acrylic solid color and mixed acrylic basecoats, and can be added up to 10% by volume. RAPTOR cannot be used with water based, polyester, or enamel paints.
#5 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 05 December 2019 - 10:44 AM
So it's compatible with celly?
#6 mattmiglia
mattmiglia
  • 515 posts
Posted 07 December 2019 - 11:29 AM
from the TDS
Thank you
