Which Ignition Coil For Metro Electronic Ignition
Posted 30 November 2019 - 08:49 PM
Which Ignition Coil do I need to go with a Metro Electronic Ignition?
Posted 01 December 2019 - 07:35 AM
Posted 01 December 2019 - 08:22 AM
https://simonbbc.com...e-black-finish/
Use without a ballast resistor
Ac
Edited by ACDodd, 01 December 2019 - 08:30 AM.
Posted 01 December 2019 - 08:39 AM
Woah, there is no ballast wire fitted to this system it uses a coil of 1.5ohms (not less) supplied with full battery voltage.
Ac
Most mk2 metros has the lucas electronic dizzy and a balast wire
Posted 01 December 2019 - 11:09 AM
Posted 01 December 2019 - 11:31 AM
Gcl143 is the correct item. There is no ballast.
That's the old unipart number, I still use this for cross reference
Posted 01 December 2019 - 04:34 PM
Posted 01 December 2019 - 04:40 PM
The GCL143 is 0.9 Ohms, AC mentions 1.5 Ohm. The Metro Distributor is a 65D IIRC.
Yes that's correct, I run a GCL143 in all my minis as they're all A+
Posted 01 December 2019 - 05:37 PM
Confused as ever
Posted 01 December 2019 - 05:42 PM
Confused as ever
Use GCL143 as a part number for cross reference, that's the number I use on Ebay etc.
Posted 02 December 2019 - 12:06 AM
You can tell when wired wrong, you get a part throttle misfire below 2500rpm. The original coil is 1.5ohm, modern replacements are 0.9ohm and will not perform as well. Try a proper 1.5ogm unit and you feel the difference in part throttle torque.
Ac
Edited by ACDodd, 02 December 2019 - 12:08 AM.
Posted 02 December 2019 - 10:19 AM
https://www.minispar...sic/GCL143.aspx
or
https://www.minispar...43.aspx|Back to
Edited by beardylondon, 02 December 2019 - 10:20 AM.
Posted 02 December 2019 - 11:55 AM
Incorrect MK2 metros with 998 engines used a ballast system. The MK2 metros fitted with the 65dm4 dizzy (1275 engined cars) used the same 1.5 ohm coil and no ballast circuit.
Ac
So any of the Viper Dry Sport Ballast 1.5 Ohm, but without the additional ballast wire.
https://simonbbc.com...sports-ballast/
Posted 02 December 2019 - 10:41 PM
Ac
Posted 03 December 2019 - 12:42 PM
I can't say I've ever seen anything other than a GCL143 equivalent with factory electronic ignition. That's with a "black box" amplifier module whether separate or screwed to the side of a type 65 dizzy.
I've also no reason to doubt AC saying he used 1.5ohm coils, but I am puzzled how one with greater impedance would work better. The opposite is true if you mismatch ballasted & unballasted coils. The 3 ohms in the ignition circuit appears to be there to keep the points from melting and the electronic system does away with those.
