Mk3 Door Seals Installation
9 replies to this topic
#1 Alex Bromo
Alex Bromo
  • 13 posts
  • Local Club: Mini
Posted 24 November 2019 - 08:46 PM
Hi all,
I recently bought on Minispares the new door seals for my '82 Clubman Estate: i noticed two slots on it (see image below) but I does not know where they should be located in the door frame (up, down, near the corners ?).
screenshot-www-minispares-com-2019-11-24
Thanks for help !
:proud:
ALex.
Edited by Alex Bromo, 24 November 2019 - 08:47 PM.
#2 Cooperman
  • 23,276 posts
Posted 24 November 2019 - 09:24 PM
The two ends of the seal should meet mid-way along the lower door frame seam. Thus the two cut-outs are in the lower corners.
#3 GraemeC
GraemeC
  • 7,438 posts
Posted 24 November 2019 - 09:32 PM
The two cut outs should align with the drain holes on the bottom of the door.
#4 imack
imack
  • 2,103 posts
Posted 25 November 2019 - 05:56 AM
I fitted mini pretty much as Cooperman said, don't know if the slots align with the door drains though.
#5 Alex Bromo
Alex Bromo
  • 13 posts
  • Local Club: Mini
Posted 25 November 2019 - 07:17 AM
Nice installation !
Was your seal in the right lenght or you had to cut it ?
ALex
#6 imack
imack
  • 2,103 posts
Posted 25 November 2019 - 07:42 AM
Nice installation !
ALex
It was the correct length
#7 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 25 November 2019 - 09:14 AM
They may not look it but they are the correct length. Don't cut them!
When I was stuck on the same question of where the holes go I phoned up minispares (they supplied the seal after all). The numpty I spoke to on the phone told me "the holes were for the control rods(???) maybe they operated the locks?". Words fail me.
#8 Alex Bromo
Alex Bromo
  • 13 posts
  • Local Club: Mini
Posted 25 November 2019 - 09:10 PM
:lol:
ALex.
#9 Aussie Steve
Aussie Steve
  • 13 posts
Posted 30 November 2019 - 02:42 AM
Nice installation !
ALex
Can you tell me what the correct length is, please? I have been supplied with cut length seals that are longer than the originals by about 6 inches. There is no way can I compress them enough to fit.
Also as there are no cut-outs, is that something I should remedy?
Thanks in advance for you advice.
#10 imack
imack
  • 2,103 posts
Posted 30 November 2019 - 10:45 AM
I make them 127.5 inches.
I wouldn't worry too much about the cut outs, the originals on my 72 didn't have them although there were some small holes punched in the seals but I'd presumed they were to let the air out and the seals compress as the joint had a solid but compressible joining piece effectively creating an endless seal.
