Radius Arm Reaming Tool
11 replies to this topic
#1 miniracer115
miniracer115
  • 30 posts
Posted 23 November 2019 - 09:41 PM
Can anyone give me the dimensions to make up a radius arm reaming tool similar to the factory tool. I bought a short 13/16 ream and want to make it into a proper tool and have access to lathe to do this.
Also I’ve seen that the correct tool have a bush that fits into the roller bearing end to guide the reamer inline. Is the roller bearing fitted first and then the bush fits inside the roller bearing to ream it or do you fit the roller bearing after you have finished reaming.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 23 November 2019 - 11:07 PM
I don't have any dimensions but as you say there is a guide, this is in place of the bearing when reaming and then the grease tube goes in then the roller bearing.
#3 drs
drs
  • 21 posts
Posted 26 November 2019 - 10:59 AM
the tools bush fits on the needle roller bearing end, once you have removed the old needle roller.
you fit the new one once you have cleaned out the swarf from the reaming.
i hope you got a hand reamer, its tapered, a machine reamer is not and very hard to use by hand.
paul
Edited by drs, 26 November 2019 - 11:00 AM.
#4 Spider
  • 14,836 posts
Posted 26 November 2019 - 06:37 PM
I made my Pilot from an old Trailing Arm Pin
#5 Dylpants80
Dylpants80
  • 64 posts
Posted 11 March 2021 - 08:21 AM
Can any one tell me What size adjustable reamer is needed for the brass bush?Thanks
#6 GraemeC
GraemeC
  • 7,438 posts
Posted 11 March 2021 - 09:18 AM
13/16" as per the first post.
#7 Dylpants80
Dylpants80
  • 64 posts
Posted 11 March 2021 - 06:42 PM
Thanks. And what type of grease should be pumped in with them? Multi purpose?
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 11 March 2021 - 07:15 PM
LM grease.
#9 gaspen
gaspen
  • 939 posts
Posted 03 November 2024 - 03:26 PM
It is satisfactorily accurate  ?
I bougth one from ebay where the reamer and the pilot screwed together. Unfortunately the thread in the rearmer is "angled" so the two pieces aren't in the same centerline
There is a small workshop in my area where the old prof could do it, but I don't know which way to choose
Actually I have the old pivots...
Attached File  20241103_152211.jpg   56.23K   5 downloads
#10 Spider
  • 14,836 posts
Posted 03 November 2024 - 05:08 PM
Whoa !  That's pretty poor !
Mine are an interference slip fit, if I had any doubts with it, I wouldn't use it.
Any decent machine shop should be able to do them. I have seen them done using a lathe, where the reamer is held in the head-stock chuck and the bearing end of the trialing arm centred on a dead centre of the Tail-stock.
While the size of the shaft s 13/16", there does need to be some clearance between that and the bush. I give mine 0.001" over that for clearance.
#11 gaspen
gaspen
  • 939 posts
Posted 04 November 2024 - 07:10 AM
I see, thanks
As I see the interference part of the shaft machined for dimension 'A' , right ?
I mean it will allow enough support for the blades on the reamer
Maybe mine has some spare material around the hole to not cut through the slots of the blades.
Attached File  el2uadB.jpg   60.08K   1 downloads
Attached File  20241104_080609.jpg   52.56K   2 downloads
#12 Spider
  • 14,836 posts
Posted 04 November 2024 - 07:44 AM
Yes, that's correct.
Looking at yours here, it might be salvageable, if there's a bit of play in the threads.
The mating faces on the end of the reamer and the pilot may not be true. They could be faced in a lathe, then when done up tight, they should pull true.
