Front Frame Does Not Fit
6 replies to this topic
#1 Elliott_12
Elliott_12
    Starting My Mini Up
  • 2 posts
Posted 14 November 2019 - 01:25 PM
I have a vtec road kit I am putting together here in the USA
I was wanting to mock up the frames and get it to a rolling shell and as I was lining up the Zcars front frame to mini shell. The tower bolt holes do not line up with the bolt mounts for the frame. It has roughly a 1/4 to 1/2 inch deviation off center
How should I remedy this fitment issue?
Is it a modification or tweaking of Zcars frame or slight modification or relocation of mini shell subframe mounting hole?
#2 minibugga
minibugga
  • 87 posts
Posted 14 November 2019 - 02:54 PM
Hi Elliot,
I would suggest you either compress the tower mounts with a strap or you expand them with a jack. These little misalignments are quite common, don't worry.
Regards, Gonzo
#3 MiniMadRacer
MiniMadRacer
  • 873 posts
Posted 14 November 2019 - 03:23 PM
You assume all Mini shells were "jig aligned".. sadly nope :-)
#4 Tupers
Tupers
  • 4,127 posts
Posted 14 November 2019 - 08:12 PM
Is it too wide or too narrow?
I’ve seen a lot of people’s Zcars builds where they’ve had to draw the tower bolt sections together with a ratchet strap to get the tower bolts to line up. It seems like they weren’t measured between coming off the jig and going out to the customer.
#5 Elliott_12
Elliott_12
    Starting My Mini Up
  • 2 posts
Posted 18 November 2019 - 12:48 PM
The towers on front frame are wider or spread apart more then the shell
If I am to bring the tower arms closer together how much or how are my chances of not cracking the powder coat?
I had that idea but I was convinced that the way the frame is welded and reenforced I wouldn’t be able to get it to budge enough
#6 Tupers
Tupers
  • 4,127 posts
Posted 18 November 2019 - 01:44 PM
As above it’s just a problem with the how Zcars made them that never seemed to get corrected.
Here’s a thread discussing the issue and another build thread showing how the subframe had to the strapped to make the towers line up with the body.
http://www.theminifo...-busavan/page-4
http://www.theminifo...l/?fromsearch=1
#7 wreckitralph
wreckitralph
  • 180 posts
Posted 18 November 2019 - 11:11 PM
 i get the need to ratchet or compress to get in to position in order to bolt them up t the body  but i may well be wrong but i wouldnt think thats ideal having the towers under constant spring out tension  i would think it could maybe lead to stress cracking
