998 Head Gasket Disaster
#16
Posted 16 November 2019 - 08:21 PM
Pressure are all good I would say and similar so think your reading to much I to it..
Even try some wd-40 in there clear out the seal.
Would also consider removing the rocker cover and inspecting that for any leaks as their a lot easier than a head gasket..
Stay calm and learn some new sweary words at the car....
#17
Posted 18 November 2019 - 12:43 AM
2nd test this afternoon, still all good. The oil/bubbles at the head/block seam haven't appeared since the first straight water flush.
Today I did a run up to temp and watched the gauge for good thermostat cycling, then an extended idle and some good revs interspersed.
I let everything totally cool --easy as it was only 43 F today--for a few hours before pulling the radiator cap. -no poof! I think we saved her, gang!
Quite the learning experience, and yes a lot of info from the norosion website that turned me off on those waterless products. It still astonishes
me that the thicker propylene glycol and higher temps could cause 2 such distinctive reactions. I'm just thrilled it doesn't appear I've done
any damage requiring a lot of back-tracking work.
I'll save the new sweary words for my MG and spring for something fun to reward the Mini... chuffed!
