My Project Engine(S) And Gearbox(Es)
engine
28 replies to this topic
#1 MaximMini
MaximMini
  • 226 posts
Posted 10 November 2019 - 12:00 PM
Hello Everyone,
Part of of my restomod project (link below) will obviously be the rebuild of my engine(s) and gearbox(es). Why plural when the restomod project is about my 91 Mini Cooper you may ask. Because inthe process I will build up a second unit for further use :shades:.
Both units will be of more or less the same specification which means 1293 ccm with MS Evo cam and HIF 44 carburettor. More details to come as soon as I have decided with hopefully the help of you guys.
Here are some photos of one of the short engines as provided by Faxe racing here in Germany
And one of the gearboxes after dismantling
And the first question, do you agree that the idler gear housing is reusable? I'm a bit concerned about the face of the input gear bearing.
This is the first set of spares which I received from John Guess
The idea is to have a full set of spares available and then reorder what was actually used for the second build.
What is your opinion on the diff bearings? Reused good thrust bearings or change to new non-thrust?
Next are the cylinder heads which have been reworked using race spec valves of 35,6 and 30 mm diameter respectively.
Is it worth the effort to opening up the outlets to meet the gasket opening?
I hope that this will become one of those threads that provide some useful information to everyone and not only to me and want to thank you guys for your input.
Cheers from the Pied Pipers Town
#2 MaximMini
MaximMini
  • 226 posts
Posted 10 November 2019 - 12:04 PM
And one more curiosity to add to my findings during disassembly of the gearbox.
D9LCrOi.jpg?1
I wonder how you can alter the number of teeth while driving :D  ..
Edited by MaximMini, 10 November 2019 - 12:13 PM.
#3 Spider
  • 14,579 posts
Posted 10 November 2019 - 04:28 PM
Hi and I hope you have fun with your builds :proud:
The Idler Thrust Face in the Transfer Housing does look worn, but also looking at the Gearbox side of this, there's misalignment between the Transfer Housing and the Gearbox Case, which I've found top be very common, in fact, I'm yet to find a set that is aligned.
In regards to the Diff Bearings, they are quite big for their duty and so they don't work too hard. Pretty much any of the types of Bearings available will be fine here. I seldom replace them.
#4 MaximMini
MaximMini
  • 226 posts
Posted 19 November 2019 - 07:43 PM
Hi Everyone,
Having invested in some measuring equipment I was finally able to take some measurements on my cylinder heads and the push roads.
Firstly I have measured the depth of the valved in the head which I expected to be quite consistent considering that the heads have been done by Faxe Racing. And indeed, the measurements vary by only two tenth of a millimetre (0.008").
Next the depth of the valve spring seats. This is lefty left-hander on a bad Monday again. The depth vary by one millimetre (0.04")!
Hard to see in the pictures but the depth vary in between 11.4 (0,45") and 12.4 mm (0.49").
What is the general opinion on this matter? Obviously it would have been best to have the seats redone to a higher spec but what can been done now? My idea is to select the valve springs accordingly (softest spring on the highest seat). Any comments?
And last but not least the overall hight of the heads:
Both heads measure 69.6 mm (2.74")
Using a dial indicator gauge, I measured the push road length compared to the shortest one. What I found was a maximum difference of 0.25 mm (0.01"). I have read some articles about the importance of the push road length but since these engines won't be top end race engines, I will most likely just take sets of four push roads which are within a tenth of a millimetre for each set of inlet and outlet valves respectively. Again any thoughts about this matter?
#5 MaximMini
MaximMini
  • 226 posts
Posted 01 December 2019 - 07:04 PM
Hi Everyone,
On Friday 10 kgs (20 lbs) of shiny shininess arrived from the platers
FEVd7lP.jpg?1
EhpGcis.jpg?1
It's been the first time that I have given parts for re-plating and I have been really worried about the outcome. But then everything went really very well and I'm actually chuffed with the overall results. On e thing that I will do different next time is that I will check all those parts that will be on display more carefully and rectify any blemishes in the surfaces before sending the parts to the plater.
And finally I decided to reassemble the cylinder heads today. I have spend ages to measure the valve springs and the heads (depth of the valves and of the spring seats) before selecting the springs so that the spring pressure when assembled will be very close to the same across the inlet valve and outlet valves of each head. I don't have the equipment to accurately measure the assembled length and the spring rate at that length but am confident that I have measured the differences the best I can.
Here are some pictures
wfWk5rI.jpg?1
pffLhAO.jpg?1
jehmv0V.jpg?1
i5f7fUO.jpg?1
And last but not least I measured the diff output shafts, diff cage bushes and crown wheel bushes to see if I have to get new bushes fitted.
The measurements read:
- diff output shafts: 26.13 .. 26.15 mm (1.029 .. 1.030")
- crown wheel bushes: 26.22 .. 26.24 mm (1.032 .. 1.033")
- diff cage bushes: 26.30 .. 26.32 mm (1.035 .. 1.036")
This means a maximum clearance of 0.19 mm (0.007") which looks ok for me. Which is a bit strange is the fact that, while the measurements on all crown wheel bushes are within a very small range as are the measurements of the diff cage bushes, they are actually different.
Have you come by this situation and what is your opinion on the clearances?
#6 Spider
  • 14,579 posts
Posted 01 December 2019 - 07:37 PM
I hope you don't mind, but I've moved your thread to the Projects section as this is a more appropriate area for it.
#7 MaximMini
MaximMini
  • 226 posts
Posted 01 December 2019 - 07:41 PM
Thank you very much
#8 MaximMini
MaximMini
  • 226 posts
Posted 01 March 2020 - 04:50 PM
Hi Everyone,
Today I made start on reassembling of my first gearbox. First I pressed in a new bush for the rod change linkage which went in quite easily:
I used two 7/16" washer on each side so that the inner bush would stay centred while the outer bush went in.
Next I moved on to the diff. side cover bushes:
I have done some spare while I was on it ;D.
With the bushes in the crownwheel I unfortunately had some problems. While on one crownwheel the bush went in ok, on another it was a pain an I ended up with lots of swarf. I hope that you can see on the next picture
Will this still be ok?
Finally I made good use of the spring like weather and painted the last aluminium parts with clear coat for protection. Some impressive accumulation of gearbox parts :D
Cheers from the Pied Piper's Town
#9 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,019 posts
Posted 01 March 2020 - 07:22 PM
Great work! How did you clean the diff covers? Are you going to machine / bore out the bushes yourself?
#10 MaximMini
MaximMini
  • 226 posts
Posted 01 March 2020 - 07:46 PM
Hi Alex,
I have glass bead blasted the side covers before I have protected the outer surfaces with a special (for engine and gearbox parts) clear coat.
Since I have no lathe (and never learned to properly use one either), I will have someone do it for me. Hence I have rebushed every part in one go.
#11 MaximMini
MaximMini
  • 226 posts
Posted 08 March 2020 - 03:46 PM
Hi Everyone,
a lot of sorting and organising ended with my take on the 'box in a box' theme ;D
Except a 2nd gear and some replacement parts I have everything for build two gear boxes now  :D .
The speedo drives are not ideal but the ones I need (TXF10004 and TXD10006) have been used on the SPI Minis only which means that they are not to easy to obtain particularly here in Germany.
Edited by MaximMini, 08 March 2020 - 03:48 PM.
#12 MaximMini
MaximMini
  • 226 posts
Posted 15 March 2020 - 07:02 PM
Hi Everyone,
What a setback with the cracked gearbox casing
http://www.theminifo...-housing-scrap/
Anyway, with all the parts cleaned I started assembling the first mainshaft with my son today. First my son reassembled the synchro hubs using the special tool from John Guess
This tool is a real game changer.
And then on to the mainshaft
When time allows I will get the spare gearbox housing and clean and paint it to the same standard I did to the first one.
Edited by MaximMini, 15 March 2020 - 07:04 PM.
#13 MaximMini
MaximMini
  • 226 posts
Posted 07 April 2020 - 11:42 AM
Hi Everyone,
Not a lot to be reported here. After I found one of the gearbox casings to be scrap, I finally got another one cleaned and painted as a replacement. Hope to have some progress to be shown here soon.
#14 MaximMini
MaximMini
  • 226 posts
Posted 20 April 2020 - 05:46 PM
Hi Everyone,
I had a crack on the first gear box with my son. All went reasonably well and it wasn't long before we could torque the mainshaft nuts. To hold the casing in position we came up with this:
We really took our time and checked and rechecked everything over and over again. I never thought how satisfying changing the gears on a (self) build gearbox can be :shades:. My son now knows exactly how everything works and is looking forward to share his knowledge with his driving instructor when he can finally start his lessons.Unfortunately I still have nobody who could machine the bushes for the differential which meant that we had to stop at some point in the building. Still we managed to prepare everything for the final build. And that's what the final product looks like:
And while we were on it and had all the parts (except the needle rollers for the layshaft) for another build we cracked on and assembled the second gearbox. Again my son changed gears driven by his overwhelming enthusiasm, when disaster struck. While changing into fourth he pushed the gear selector shaft a bit to far which resulted in the balls and springs escaping the synchronising ring :ohno: . That meant disassembly of the mainshaft from the box which has to start with the disassembly of the 1st motion shaft which we haven't the tool for. Anyway, a bit of ingenuity later we came up with this:
Another happy ending story then :D . Even better, I finally found a reseller which has the missing needle bearings of IMA brand on stock. To be continued ..
Edited by MaximMini, 20 April 2020 - 05:50 PM.
#15 MaximMini
MaximMini
  • 226 posts
Posted 02 May 2020 - 06:22 PM
Hi Everyone,
With the gearbox builds having come to an halt, I made a start on the first engine. This engine will be based on a SPI short block which I got readily build from Faxe Racing.
First I applied some fresh paint which is the worst job for my liking. I went for olive green for the retro look.
Next I dry build the block ancillaries on to see which hardware would go where. I had most hardware re-plated which meant that I had to check each nut and bolt. I did this whithout gasket and made sure that every bolt would go in by hand without buttoning out. And that's what it looked like:
Next I disassembled everything again and created reference pictures so that I wouldn't have to start again on the next engine. I'm fairly confident that I have referenced the correct hardware but if you are using the references in the future make sure that you consider any differences in engine size and age.
Not having grown up in the world of inches and their increments, I have measured the length of the bolts in millimetres ;D .
I then disassembled the oil pump to get it de-burred and to apply some oil to help with the first priming. And last but not least I got out my Haynes manual to check for clearances and torque settings. That's where I left it today, waiting to start assembly with my son when time allows.
Two questions I have for you guys:
1) What diameter hole do I need to bore for the engine plate rivets?
2) Do I need only a different (to the 91 Cooper) oil pipe or is the oil filter adapter different as well?
Stay safe!
