Rebuilding A Moto-Lita Steering Wheel: Tips And Tricks
16 replies to this topic
#1 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 05 November 2019 - 10:49 PM
So here is the story: the other day, I found in a garage sale a vintage moto-lita (probably genuine, but not sure), that was mounted on a Triumph Vitesse in the late 60's. it came with a Triumph center cap. I'm not an expert in Triumph so, I don't know if it was an option at the time, my bet is that it's an after market of some sort.
the wheel was in terrible condition, but I thought it could be a good idea to learn and practice how to remake a steering wheel. here is how it looked like when I bought it: >_<
Attached File  IMG_20191101_215618_271.jpg   57.32K   4 downloads
the leather is completely coocked, and falls appart just by looking at it with a mean face. but the rest seem to be in good shape. so I scrapped the leather, and peeled off the rubber/foam that covers it. here is how it looked like:
Attached File  IMG_20191101_215618_273.jpg   61.13K   4 downloads
after a few hours of polishing and gentle sanding of the most corroded parts, I ended up with somethink like that:
Attached File  IMG_20191101_215618_272.jpg   56.82K   4 downloads
it's shinny again and I could remove most of the scratch using 1000 sanding paper.
Attached File  IMG_-5i4q11.jpg   33.32K   3 downloads
the foam was in decent condition, so I cleaned it and glued it again. it's more tricky than it sounds: indeed if the ends of the rubber do not exactly match, it will be visible with through the leather. any irregularities will do. so be careful if you do it. wrap it good so it stays in place.
Attached File  IMG_20191102_115710-W900.jpg   75.24K   3 downloads
Another tricky part is the width of leather you have to cut:
if it's too long, the wheel will feel squishy.
if it's too tight, the leather will loose its grain and look and feel terribly flat. plus leather is not that stretchy. So I made a test case using a little piece of leather. turns out that edge to edge, if it is 86mm in total, it will wrap nicely around the wheel with the tension cross stitch.
Attached File  IMG_20191102_130926-W900.jpg   20.62K   3 downloads
Now comes the real deal: I have to cut large pieces of leather to fit the entire wheel. you can do it with one piece that you will stitch together at one end. but it's over a meter long and I did not have a skin that was large enough here. especially since I chose automotive grade leather, UV resistant. It does not come exactly cheap, so I decided to cut it in 3 pieces, with one junction at the top, and 2 junctions at the bottom, nicely symetric over the vertical axes but not equidistant, on purpose.
Attached File  IMG_20191102_210414_677-W900.jpg   39.01K   3 downloads
for that purpose, you want a rather thin skin (about 1.2 / 1.5mm max). because if it's too thick it won't feel right. and if it's too thin, it will be too stretchy.
Now before you put that on the wheel, you have to stitch your pieces as a leather band, that will be later put around the wheel. Here again, you don't want too tight or too lose. but if you cut your segments large enough, you have some room for tests.
on the long axis, I folded the leather and saddle stitched by hand. to join the sections of the band together, I use a french seam stitch. it's basically a very strong stitch where you join both pieces together on the nice skin surface, and fold the flesh face on the back and then only saddle stich those folded elements in place. you can use a thin foil of polyesther in the back for additionnal stretch, but to be aware: the more pieces you stack, the less stretchy it becomes. so it will become harder to fold around the wheel. the 2 bottom junctions are black stitches:
Attached File  IMG_20191102_222547_017-W600.jpg   53.44K   2 downloads
and I chose red for the top stitch, so it acts as well as top mark. it's still discrete and I thought it was a nice touch :gimme:
Attached File  IMG_20191102_231918_378-W600.jpg   37.06K   1 downloads
then the leather is put on the wheel, and folded around it. to keep it together, the traditional method seems to to a cross stitch using the loop of the stitch and not through leather. it adds some elasticity to the method and puts a bit less stress on the leather.
Here you can see a detail of it.
Attached File  IMG_20191104_141459_682.jpg   36.29K   2 downloads
and here is the final wheel ! :proud:
Attached File  IMG_20191104_071938_508-W900.jpg   55.38K   2 downloads
I'm quite happy because the leather kept enough grain. it's not too tense.
Attached File  IMG_20191104_081515-W900.jpg   32.68K   3 downloads
and all the metal to leather junctions are quite flat.
Attached File  IMG_20191104_081729-W900.jpg   24.76K   2 downloads
All in all, the end result is pleasing, I think. It could be improved of course. for instance, I could (should) have carved out the foam to accomodate the thicker seam stitching. but it's not too bad. Hope this helps someone if you decide to go for it.
what do you think ?  ;D
cheers guys!
#2 I hate Brian
I hate Brian
  • 782 posts
Posted 06 November 2019 - 07:01 AM
Well done excellent work Benoit
#3 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 06 November 2019 - 10:19 AM
Which thread did you use?      Different sites recommend different threads -Bonded Nylon, Waxed Linen etc. None seem to meet ALL the requirements ie strength, moisture resistance, UV resistance etc.
Is your thread a little thicker than the original?       -maybe it just looks thicker in close up photos.
#4 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 06 November 2019 - 10:35 AM
Thank you! I try my best.
#5 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 06 November 2019 - 10:41 AM
So for leather I used here 0.8 braided waxed polyester thread. It's similar size to what was in place originally. It has several advantages:
It is very strong. And you can melt it to solder Stitch stops if you want it to be very strong. Basically you make a knot and you melt it. Won't Come off easily.
#6 Chris1275gt
Chris1275gt
  • 938 posts
Posted 06 November 2019 - 11:02 AM
Benoit
That is a quality piece of work. Having repaired various leather pieces before I know how difficult it is, but that is way beyond my skill.
Did you see my last post on your photos of your car where I think I identified your dash wood.
#7 KTS
KTS
  • 2,421 posts
Posted 06 November 2019 - 11:12 AM
nice job Benoit.
certainly looks like a genuine MkIV moto-lita.  it's a small boss version too which i think look nicer than the more modern ones.  it's good that it came with the top ring  too, as they don't appear to make them any more
correction :  looks like a MkVI not a MkIV
http://mk1-performan...simon_green.pdf
Edited by KTS, 06 November 2019 - 01:48 PM.
#8 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 06 November 2019 - 12:19 PM
Nice write up, I seem to remember you mentioning this on FB a year so so ago, I've still not managed to start mine.
What a great mini friendly place to live as well - now you have the steering wheel to match the roads.
#9 slidehammer
slidehammer
  • 1,194 posts
  • Local Club: LSMOC
Posted 06 November 2019 - 01:24 PM
one word - stunning!
#10 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 06 November 2019 - 02:05 PM
Benoit
Hi, Yes I did, thank you very much for your kind word. I did not answer yet, but I should have answered. sorry for the delay. I come back to you on that one :)
#11 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 06 November 2019 - 02:07 PM
nice job Benoit.
thanks for the tip! I did not know which one it was!! sure it's a small boss. it does not fit my moto-lita wood bought last year. those new bosses are so large.
#12 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 06 November 2019 - 02:08 PM
thank you very much for your words! turns out, it must have been someone else. I don't own a FB account :)
#13 Benoit_Dupont
Benoit_Dupont
  • 291 posts
thank you!!!
#14 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 07 November 2019 - 08:46 AM
Benoit,
This is amazing, and really useful for me - thank you! I also have an old Moto Lita wheel. I have no idea what year it is or what car it is from, but it has three holes per spoke instead of two. Probably off a Stag or something?
I only bought it because it was cheap, and had a lovely aged look but you've got me thinking about restoring it now. Excellent work!
#15 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 07 November 2019 - 09:44 AM
Benoit,
Glad to help! If you have any question, don't hesitate to contact me! Cheers mate!
