She Dies In The Middle Of A Trip Now
24 replies to this topic
#16 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 16 October 2019 - 07:26 PM
Your symptons are the same i had...Hope it helps!
Part ordered!
https://www.7ent.com...on-vzx1100.html
And I'll drive around tonight with the gas cap off as I wait for the viton tip to come in the mail.  I'll report back tomorrow.....
Thanks!
Ryan
#17 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 16 October 2019 - 09:19 PM
What I usually do is drive the car till it dies, then immediately open the gas cap, if theres pressure inside you will hear it, does the car start straight away after this?
The remedy here being the cap is non vented or the vent hole is blocked.
Hope this helps
Cal
Edited by cal844, 16 October 2019 - 09:22 PM.
#18 Benoit_Dupont
Benoit_Dupont
  • 291 posts
Posted 16 October 2019 - 09:29 PM
Agreed !
#19 Ethel
  • 25,919 posts
Posted 17 October 2019 - 12:18 PM
Don't be fixed on the idea it must be fuel because the choke has an effect. A faster flywheel and less inlet vacuum to pull against will help overcome any loss of engine power. A richer mixture can also help ignition from a poor spark or compensate for an air leak downstream of the jet.
If it was a fuel supply issue, the choke would only have a short lived effect as the float chamber empties faster.
Have a look at the spark plug colour immediately after it starts playing up and give the ignition the once over. You don't need the engine to be running, like you do to set up the fuelling and without correct ignition performance you'll never manage to test &  adjust the fuelling properly.
#20 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 17 October 2019 - 06:20 PM
I was going to take it for a drive, but the carb needle was stuck, and a small pool of gas poured out.  Good thing the new part is on its way.
As I was letting the car warm up, a LOT of white smoke was coming out of the exhaust.  White with a little tint of blue in the light.  Thoughts on the problems behind that?
Thanks guys,
Ryan
#21 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 17 October 2019 - 06:23 PM
I'll check this out over the weekend, when I can install the carb needle! Thanks!
Also -- I installed new spark plugs and wires over summer.  I gapped the plugs, too.  But I'll take a look and a few pictures.
#22 Cobra64
Cobra64
    Just On Tickover
  • 7 posts
Posted 21 October 2019 - 10:39 AM
Usually....
White smoke = burning water
Blue smoke = burning oil
Check if you are losing either
#23 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 24 October 2019 - 07:53 AM
Everything electrical's brand new (or a year old by now).
Did you change the condenser and/or rotor arm? A lot of the new items are very poor quality and prone to early failure.
#24 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 21 December 2019 - 01:08 AM
Real close guess! It turned out to be a wire to the rotor arm.  I cut it out, connected a new wire, and it was up and running!  Thanks!
#25 Pairaminis
Pairaminis
  • 194 posts
Posted 21 December 2019 - 12:56 PM
Curious if you mean it was a bad wire to the points?
