I use blue Hylomar on all paper seals and the loctite 5922 underneath, on it and on the ends of the half-moon seal, where they meet the paper gaskets.
Loctite 5922 Flange Sealant Product description
The Loctite 5922 Flange Sealant a slow drying, flexible setting paste that changes to a pliable, non-hardening film through solvent evaporation. It seals flanges, fittings, connections and flexible assemblies against leakage and increases the reliability of gasket seals.
It is suitable for valve cover gaskets, oil pan gaskets, threaded connections, cover plates and hose connections.
features & benefits of Loctite 5922 Flange Sealant
- Improves reliability
- Extends gasket life
- Stops leakage
- Excellent for all metal to metal assemblies
- Slow drying
- Flexible setting
- Withstands temperatures of -55 to +200C
- Suitable for: valve cover gaskets, oil pan gaskets, threaded connections, cover plates & hose connections
Edited by floormanager, 14 October 2019 - 08:06 PM.
