Wiring Caerbont (Aka Smith's) Gauge?
Posted 08 October 2019 - 03:20 PM
Brown/slate: Pull up for ECU output
Red/white: gauge lighting
Red/blue: tacho out from ECU or contact breaker or alternator W terminal
White/black: same but high sensitivity
Black: ground
Green: switched ignition positive 12V supply.
So now my question: the car obviously has no ECU (88 Mini( so do I just wire gauge lights, contact breaker (via the coil??), The ground and power? So using only 4 out of 6 wires?
Thanks!
Posted 08 October 2019 - 05:02 PM
Yes, you would only use 4 wires;-
Red / White Lighting
Red / Blue Points. This connects to the wire from the Coil to the Points.
Black Earth
Green Switched + ve
Posted 08 October 2019 - 06:37 PM
Just to be sure, the tach sending lead goes on the coil negative right?
Posted 08 October 2019 - 07:58 PM
Okay, great, just what I needed!!!
If the negative terminal of the coil is connected to the contact breakers then yes it does.
Posted 09 October 2019 - 02:10 PM
Posted 09 October 2019 - 02:27 PM
Are you sure you got the red/green wire and not a green/red wire by mistake. If you got the green/red one then the backlight will flash in time with the left hand indicators!
Posted 09 October 2019 - 02:37 PM
Now I have a problem with the gauge lighting... I spliced into the red/green wire for power and black for ground but no dice on the backlight...
Why have you used a red/green for power? The feed you need is a solid green (ignition switched live).
Posted 09 October 2019 - 06:05 PM
The Back Light on the Gauge is the Red / White wire. In the Loom on the Car, the Wire to spice that in to will be either Red or Red / White.
Posted 09 October 2019 - 06:51 PM
Posted 09 October 2019 - 06:53 PM
Yes, for the lighting you need to use red/green because otherwise the gauge lights would be on non-stop (or well, anytime igniton is on)
