Obd1 Or Obd2?
Posted 08 October 2019 - 03:29 AM
Posted 11 October 2019 - 02:44 PM
Posted 11 October 2019 - 07:46 PM
Mine was a b16a2 from a ‘94 del sol. Same loom can be used for the jdm b18c motor too.... so I did :)
Posted 14 October 2019 - 07:26 PM
Posted 15 October 2019 - 08:03 AM
You’re best off with obd1 loom and motor in my opinion.
Posted 17 January 2020 - 07:26 PM
obd1 loom means you are stuck with a b16a. Dont worry about what OBD it is if you are not going to Re-map. If you get a B18 or B18R motor they are all OBD2, OBD2a or OBD2b. If you want to get any b18 engine remapped all you have to do is get a OBD2 converting jumper harness to OBD1 and then use a OBD1 P28 ECU and chip it to run software like Chrome or hondata s300 which is the best.
Edited by itsmeleon, 17 January 2020 - 07:26 PM.
