Has anybody using a standalone dash/ cluster found a way to retrieve the ECU fault codes or have a functional check engine light ?
I’m using a racepak dash but can’t find a solution for the above without using the factory R1 clocks.
Check Engine Light / Retrieve Fault Codes Without Using Factory R1 Clocks.
cad13
, Oct 06 2019 07:09 PM
No replies to this topic
