Starter Motor Beyond Repair?
15 replies to this topic
#1 AndrewT
AndrewT
  • 147 posts
Posted 29 September 2019 - 05:53 PM
My starter motor is just spinning and won't engage. Battery is fine so I took the motor apart and tried moving the pinion by hand but it wouldn't budge so is probably seized. The car has been stood for a few months.
Does this look beyond saving?
#2 weef
weef
  • 489 posts
Posted 29 September 2019 - 06:33 PM
Hi,  strip the Bendix gear off and inspect/clean. Hopefully just seized with sitting, you can probably still buy new gear assembles. You will need a special tool to remove the shaft clip. On reassembly lubricate using a "dry lube" graphite based product, this prevents the clutch dust sticking to the gear helping to give trouble free operation.
#3 richmondclassicsnorthwales
  • 942 posts
Posted 29 September 2019 - 06:37 PM
There are 3 windings on the internals, if just one is burnt out, that's it -  had it
Sometimes - can be the carbon bushes, but these starter motor things are pretty good - if it has a weld mark down the one side - it is a recon unit - and maybe had it again
Try cleaning the spindle and gear unit with WD but do not oil the unit. Oil will attract all the fibres from the clutch plate and it will stick again
Clean the lot up - and get the pinion gear to run on it,s own by pulling the pinion back and forth and getting it to return - Same as having a Barclays !!!!!!
If it does successfully - clean away all the WD - let it dry -  and then use a high HB grade pencil (HB9) and rub the shaft with the pencil - lead is the lubricant you need - not oil
#4 unburntfuelinthemorning
  • 1,982 posts
Posted 29 September 2019 - 06:55 PM
But pencils are unleaded.
#5 AndrewT
AndrewT
  • 147 posts
Posted 29 September 2019 - 07:03 PM
The motor is fine and spins up freely, it's just the pinion that won't move at all. Even with some gentle persuasion with a hammer.
When I lived in Oz there I swore by a penetrating spray called H72 Reducteur. Honestly this stuff would free up the most seized of bolts in no time. What's the best UK equivalent to soak it in these days?
#6 nicklouse
  • 18,574 posts
Posted 29 September 2019 - 08:30 PM
Does look a bit rusty that. Change it.
#7 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 29 September 2019 - 08:40 PM
Just get some penetrant on the shaft and Bendix - any will do. Once you get it freed up use dry lube as above. Nothing wrong that a good clean up won't fix.
#8 unburntfuelinthemorning
  • 1,982 posts
Posted 30 September 2019 - 06:38 AM
PlusGas is one of the better penetrants.
#9 Cooperman
  • 23,276 posts
Posted 30 September 2019 - 11:59 AM
This. There is no problem with the motor, just unstick the bendix and lubricate it with a fine oil and then wipe any excess off before re-fitting
#10 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 30 September 2019 - 01:09 PM
Did you mean graphite?
#11 DeadSquare
DeadSquare
  • 3,089 posts
Posted 30 September 2019 - 01:42 PM
For over 50 years, I have always used graphite.
I was given a puffer at a locksmith's convention in 1965, and I hope I don't empty it before I die.
#12 AndrewT
AndrewT
  • 147 posts
Posted 30 September 2019 - 07:31 PM
Thanks for the replies.
I've acquired some Plusgas and will give that a go at the weekend. If that doesn't free it then it's time for a new one.
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 30 September 2019 - 07:59 PM
Plus gas, 24 hours, bit of gentle persuasion with a hammer.
More plus gas, more time. Some heat.
#14 Cooperman
  • 23,276 posts
Posted 30 September 2019 - 09:24 PM
Be confident. It will free off without too much force, then it just needs a small amount of fine lubricant which can then be dried off as much as possible.
Test it on the bench before fitting.
This was/is a common problem with inertia starters on classic cars left standing for a while.
#15 weef
weef
  • 489 posts
Posted 01 October 2019 - 05:28 PM
Just strip the Bendix gear off the shaft and be done with it
