Authi Mini 1000
71 replies to this topic
#16 gaspen
gaspen
  • 938 posts
Posted 13 January 2020 - 05:57 PM
interesting that the gearbox was painted
Yes. They painted them brown, but not all engines.
#17 PACINO
PACINO
  • 741 posts
Posted 13 January 2020 - 10:51 PM
Hi Gaspen! You're doing a great job. I was surprised that you painted the Carter the same color as the engine. Originally this came like this? Greetings
#18 gaspen
gaspen
  • 938 posts
Posted 14 January 2020 - 10:51 AM
When I bought the car in 2018 most of the paint was removed/worn from the engine. I believe that it was the original paint from 1975. But there were small signs of paint everywhere : gearbox, clutch housing and so on. So i decided to repaint to RAL8003 as it is the closest shade to the original. The picture I've attached is from an advertisement that I found on the web. The sticker on the rocker cover shows "British Leyland Authi"
#19 gaspen
gaspen
  • 938 posts
Posted 04 February 2020 - 07:21 AM
I finished the gearbox/diff assembly. Everything is torqued, endfloats and pre-loads are set.
Attached File  IMG_20200125_171150.jpg   75.78K   3 downloads
The crank has to machined for the first undersize.
Attached File  IMG_20200126_113901.jpg   27.15K   1 downloads
#20 Itsaminithing
Itsaminithing
  • 852 posts
  • Local Club: Not One Worth Mentioning
Posted 10 February 2020 - 09:15 AM
It's probably too late to respond but....
1. I've seen examples of painted Authi gearboxes & clutch covers before. In the 1960s BMC & BMH painted their gearboxes & clutch covers.
    In the 1970s BLMC were trying to keep the cost down on the Mini in both the British & Spanish markets & only painted the engine. Perhaps only the Authi Export models had painted gearboxes & clutch covers.
2. In many pictures RAL 8003 (clay brown) looks very close to the original -but in your photos it looks far too yellow.
    Is it worth posting on foromini to find out where they buy their engine paint -it will be the same colour, they just need to buy less of it than you do.
#21 gaspen
gaspen
  • 938 posts
Posted 10 February 2020 - 12:29 PM
In real life the color is more brownish that on the pictures. I think it is because of the flashlight of the camera. I checked the color with a RAL card before I bought the spray.
Attached File  IMG_20190908_161210.jpg   30.37K   3 downloads
#22 gaspen
gaspen
  • 938 posts
Posted 02 March 2020 - 07:20 AM
The crankshaft main's has to be machined for the 1st undersize because I found something that I did not want to see : the middle main journal had abnormal wear.
After that I carry the crank-flywheel-clutch assembly for balancing. Yesterday I put together the gearbox and engine. All clearence's and endfloat's were set as in the manual.
Attached File  IMG_20200301_171421.jpg   59.36K   2 downloads
And the bodywork starts :
Attached File  IMG_20200216_141522.jpg   92.88K   1 downloads
#23 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 02 March 2020 - 10:12 AM
Funnily enough Innocentis also had the engine and gearbox painted. Albeit black rather than brown.
#24 gaspen
gaspen
  • 938 posts
Posted 09 March 2020 - 09:08 AM
Yesterday I bought a spare engine from Croatia :)
Attached File  IMG_20200308_133525.jpg   80.26K   0 downloads
Attached File  IMG_20200308_132949.jpg   84.98K   0 downloads
Attached File  IMG_20200309_072442.jpg   152.8K   0 downloads
Attached File  IMG_20200309_072343.jpg   68.21K   0 downloads
#25 gaspen
gaspen
  • 938 posts
Posted 15 April 2020 - 05:20 PM
I fall deep into the bodywork
Attached File  IMG_20200408_173048.jpg   105.37K   0 downloads
Attached File  IMG_20200321_115501.jpg   76.69K   0 downloads
I am trying to make some panels myself
Attached File  IMG_20200329_175910.jpg   77.28K   0 downloads
At least the rear subframe repair is done
Attached File  IMG_20200331_121042 (1).jpg   81.4K   0 downloads
#26 gaspen
gaspen
  • 938 posts
Posted 28 April 2020 - 10:39 AM
While waiting for the body panels I continued  to re-assembling and painting some bits
Attached File  IMG_20200427_120103.jpg   60.19K   0 downloads
Attached File  IMG_20200403_171937.jpg   82.38K   0 downloads
Attached File  IMG_20200405_175025.jpg   67.99K   0 downloads
#27 austinseven
austinseven
  • 76 posts
Posted 28 April 2020 - 12:23 PM
Love the fabrication on the a panels
#28 gaspen
gaspen
  • 938 posts
Posted 28 April 2020 - 02:03 PM
Looks nice but does not fit well to the new wings ?
#29 DeanP
DeanP
  • 499 posts
Posted 28 April 2020 - 02:59 PM
Wow amazing work.
#30 gaspen
gaspen
  • 938 posts
Posted 26 September 2020 - 06:50 PM
Good evening
After I spent the last months with cutting, griding, shaping, patching, welding, put together, measuring, test fitting, dismantling over and over, from some point of view it looks a like a Mini. Next job is to re-skin the right hand door, weld the right wing int place, and build up the front-end.
I choosed some random picture from the 400 I've made  :proud:
Attached File  IMG_20200713_185421.jpg   106.73K   1 downloadsAttached File  IMG_20200719_095042.jpg   69.1K   0 downloadsAttached File  IMG_20200803_101123.jpg   85.29K   0 downloads
Attached File  IMG_20200807_093817.jpg   74.14K   0 downloadsAttached File  IMG_20200831_112841.jpg   37.02K   0 downloadsAttached File  IMG_20200719_135559.jpg   49.02K   0 downloadsAttached File  IMG_20200707_094615.jpg   39.96K   1 downloads
Attached File  IMG_20200626_163518_BURST1.jpg   69.11K   1 downloadsAttached File  IMG_20200909_162910.jpg   74.83K   1 downloadsAttached File  IMG_20200920_164950.jpg   86.31K   0 downloadsAttached File  IMG_20200923_173612.jpg   89.14K   0 downloads
Attached File  IMG_20200925_164302.jpg   74.8K   0 downloadsAttached File  IMG_20200925_165613.jpg   47.73K   0 downloads
