Word, I pretty agree with everyone. My sentiment is simply to give it a whirl the simple way, and if problems develop, reevaluate the design.
Yankee Ev Conversion
#46
Posted 04 January 2020 - 08:45 PM
#47
Posted 05 January 2020 - 12:46 PM
Too right, all this armchair engineering is fun, but ultimately somebody has to get off their arse and have a go to achieve anything. You have my respect for doing that.
#48
Posted 06 January 2020 - 02:30 PM
Just wondering, if you use another frame based on the mini design aren't you going to have the exact same problems running out of space where the steering rack is?
I personally would continue with your mini subframe, by the way the towers lean back 4.5 degrees when fitted in the car
If you need more space where the lower suspension mounts are some people convert them to rose joints for more space for the CV's see below
https://picclick.co....ml#&gid=1&pid=5
Just out of interest I saw this article which uses a newly developed electric motor in a classic mini subframe
https://www.msn.com/...ocid=spartanntp
David
#49
Posted 08 January 2020 - 02:17 AM
Thank you for this—this is rather important niche knowledge.
The problem with those aftermarket power plants is that they cost more than all the other parts of my conversion combined...
#50
Posted 08 January 2020 - 10:19 AM
David
WOW !
That only weighs 1/2 a Mini lump.
Twin engine / four wheel drive / 200+ BHP...................away we go.
#51
Posted 24 January 2020 - 06:37 PM
Edited by Tremelune, 24 January 2020 - 06:38 PM.
#52
Posted 25 January 2020 - 12:25 PM
Progress! Very nice to see.
Is this a "Thunderstruck"-charger? (Are you not using the original charger/DC-DC/BMS,....?)
Prototype-mode is exactly what applied to my project; after 9 months on the road and so many changes, the car still continues to be a protoype. ![]()
Kep it up!
Markus
#53
Posted 25 January 2020 - 05:15 PM
Correct! It's their TSM2500 with their
charge controller and BMS.
I would have loved to use the Nissan charger, DC-DC, and BMS—it would have saved me thousands—but they're not quite hacked yet, it seems. https://www.diyelect...e DC-DC working, but took the video down (and it wasn't comprehensive). It would be amazing if someone could figure out the charger CAN bus protocol, but it's just not there yet. I might try and give it a whirl myself the next time around, 'cause you can pick up a 6.6kW Nissan charger for a few hundred bucks...You just can't control it outside a Leaf!
Most of the CAN hacking on the Leaf is being done to add features to the Leaf. That's...effectively the opposite of my goals of using Leaf components in the wild.
#54
Posted 26 January 2020 - 01:24 PM
You should have a look into the norwegian e-driver's forum: elbilforum.no
There is a huge community as they have so many cars for so many years. Someone there may have access to the Leaf's CAN protocol.
(You might even stay with the original Nissan's components, and the optional 6.6KW charger.)
Regards,
Markus
#55
Posted 10 March 2020 - 02:18 AM
The MCM subframe has arrived! It's spacious, but I'm suddenly daunted with regard to positioning the motor...It's hard to know where it should sit. Like, where should the axle outputs be vertically with regard to the subframe...
I really wish I'd taken more measurements and photos before I took the car apart. Current plan is to confirm that the axles should be centered in the stock holes, and measure that relative to the towers, and use that as the reference on the McGee subframe...
I might also install it on the car and see if I can find those chassis measurements and go from there...The sticky bit with that is the "spars" on the McGee subframe intrude upon the Mini body. For Honda swaps, you have to just cut those chassis bits out, but for my swap it's unnecessary...but that means I'll have to cut the McGee subframe and re-weld in supports. Not too big a deal, but the more I have to modify this thing, the more it seems I should have just cut the stock subframe to hell and then reinforced it after the motor was in...Blarg.
Once I have some good reference points, I'll use wooden inclined planes to position the motor, manila folder pieces to mock up mounts, then fab everything up and weld it together. NO PROBLEM
#56
Posted 11 March 2020 - 04:24 AM
Utilizing Paper Aided Design (PAD) and non-laser measuring tools, I was able to figure out where the center of the output shafts are vertically, relative to the tower tops. I'm basing this all on the assumption that axle center should be at the height of the center of the OEM axle holes.
The plan is to position the axle outputs at 3" above the lower square tubing of the MCM subframe, and as far back as I can without the motor hitting the body. I might try and weld up a little set of gunsight irons to help me position the motor...If they line up on both sides and are centered, the motor should be straight, level, and at the right height...but I might be getting a bit precious about all this.
Random info: The MCM subframe is 42 lb.
Edited by Tremelune, 11 March 2020 - 04:30 AM.
#57
Posted 25 March 2020 - 05:29 PM
#58
Posted 28 March 2020 - 10:41 PM
I'd them address any weight imbalance with chargers / inverters / dc to dc / batteries etc.
#59
Posted 30 March 2020 - 08:11 PM
I went with a different electric motor, but now have to start matching up all the other bits to suit. I guess it's part of the fun ?
#60
Posted 30 March 2020 - 08:12 PM
Bing (1)
