Is There An Easy Way To Remove ..
Best Answer g0myw , 23 September 2019 - 03:13 PM
I've not done one, but I'd go fo thr heat gun method, it works well on interior floorpan soundproof gunge
Go to the full post
4 replies to this topic
#1 Bobbins
Bobbins
  • 1,484 posts
Posted 23 September 2019 - 02:14 PM
.... the grip strip in the bottom of the battery tray? I assume it's a bonded in bitumen strip so is probably easiest removed with a hot air gun and scraper but can anyone confirm?
C2hlht3.jpg?1
#2 g0myw
g0myw
  • Just Joined
  • 108 posts
Posted 23 September 2019 - 03:13 PM   Best Answer
#3 nicklouse
  • 18,562 posts
Posted 23 September 2019 - 05:15 PM
Ain’t standard. Has it been glued in or has it got an adhesive strip.
Try heat.
#4 Bobbins
Bobbins
  • 1,484 posts
Posted 25 September 2019 - 11:52 AM
Heat gun and it lifted easily, thanks :)
#5 MikeRotherham
MikeRotherham
  • 976 posts
Posted 25 September 2019 - 03:58 PM
I've got the same in the bottom of my battery box. It is like a strip of bitumin and snaps easily up you give it a pull at one end. The bit that broke away i've replaced with a blanking plug.
