Oil Pressure Drops With Rpm
22 replies to this topic
#16 Dusky
Dusky
  • 5,322 posts
Posted 23 September 2019 - 07:18 AM
More RPM should increase pressure regardless of bearing wear. I'm voting for an air leak.
#17 ACDodd
ACDodd
  • Mini Docs
  • 2,742 posts
Posted 23 September 2019 - 07:31 AM
Oil pressure does fall with rpm as the pump turned slower. Oil pressure for a road car should be 60 to 65psi at 3000rpm hot and 15psi idling.
Ac
Edited by ACDodd, 23 September 2019 - 07:31 AM.
#18 DEXISWOLF
DEXISWOLF
  • 545 posts
  • Local Club: Steel City Classics
Posted 23 September 2019 - 08:13 AM
Ac
Mines doing the opposite :( great at idle but anything above 3500rpm its getting to 20 and will go lower
#19 DEXISWOLF
DEXISWOLF
  • 545 posts
Posted 23 September 2019 - 08:16 AM
Ive also checked and double checked when the engine came out again and changed all gaskets from pump to pickup and even filter housing and pipe too
#20 DEXISWOLF
DEXISWOLF
  • 545 posts
Posted 23 September 2019 - 08:23 AM
Check bearing clearances with plastigage or micrometers; what is the thrust bearing float clearance; have the cam shaft bearings being installed correctly and how is the clearance there. Are the oil gallery plugs in correctly - not leaking slightly. What oil are you using. There could be a problem with the pressure relief valve seat. What intake type are you using - there could be a restriction there. Hopefully you don't have blobs of silicon gasket sealer in the system.
I know i should have but i didn't check the endfloat or oil gallery plugs , the cam bearings was already installed , with it coming as a kit with all bearings included i thought that would have been checked back at jonspeed, i just installed everything thinking it was ok (i know stupid of me) :( but when i pull it again for the fourth time i think im going to check everything this time , im using a cheap 20/50 (for running in) ive used in loads of my previous minis and they have had great pressure, i also did try a better one too along with a few different filters ,
#21 MiniMadRacer
MiniMadRacer
  • 888 posts
Posted 23 September 2019 - 08:31 AM
I had a similar issue years ago on a 1275 GT A Series lump which had a hairline crack in the brass oil pressure switch / oil pressure gauge T piece. replaced that and all was good. I only found it when I decided to "plug" in a different oil pressure gauge under the bonnet and unscrewing the connector the brass T piece came out with it
#22 DEXISWOLF
DEXISWOLF
  • 545 posts
Posted 23 September 2019 - 09:13 AM
I might look at that t piece later , cheers for that
#23 carbon
carbon
  • 2,590 posts
Posted 27 September 2019 - 07:45 PM
My experience was that with worn big-end shells the oil pressure dropped off from about 1500-2500 rpm with the engine warmed up. And then above 2500rpm started to increase again.
And how do I know it was the big-end shells? Because these were worn down to the copper. The crank was OK, this being one of the few benefits of a nitrided crank...
The big end shells were replaced, and normal oil pressure was restored.
Could be an air leak, but I would suggest first checking all the mains and big-end bearing clearances with Plastigage.
