Lumenition Optronic - What Coil?
7 replies to this topic
#1 tb205gti
tb205gti
  • 186 posts
Posted 11 September 2019 - 06:52 PM
I have sourced a classic (probably 20+ years old now) Lumenition Optronic kit for my 998. My points are worn, and rather than get new points I'd like to use the Lumenition kit.
..But can I use my original coil (non-ballast) for it? it is a 1977 A 998ccm.
#2 Spider
  • 14,840 posts
Posted 11 September 2019 - 07:17 PM
These are great units, I've used a lot of them in the days before we could get the small modules that are available today.
They can handle Coil Currents up to 7 amps, so allowing for a margin here check the resistance of your Coil, you want 2.0 ohms or more.
#3 andy3lliott
andy3lliott
  • 13 posts
Posted 11 September 2019 - 08:23 PM
i have a couple of these knocking about used the medern electronic ignition dizzys and the retro fit modules but never actually used the lumination ones
#4 andyapanel
andyapanel
  • 623 posts
Posted 12 September 2019 - 11:41 AM
I used them on an Escort 2 based kit car 30 years ago. It used Ballasted ignition.
I had much better reliability with Magnetronic. The Lumenition failed twice in about 10000 miles. Lumenition replaced them, but I would rather the unit had not failed in the first place.
#5 imack
imack
  • 2,103 posts
Posted 12 September 2019 - 12:39 PM
Lumenition optronic on my mini is 30+ years old, its paired with a lucas sports coil of similar vintage.
#6 r.tec
r.tec
  • 183 posts
  • Local Club: SfG Schoenau
Posted 13 September 2019 - 10:58 AM
yes, std coil would be alright. But coils deteriorate with age. I went for a Lucas DLB105 but similar non-resistance coils are okay.
#7 tb205gti
tb205gti
  • 186 posts
Posted 14 September 2019 - 07:44 PM
Thanks for your replies - did clean it a bit today, and found a broken wire that needs to be replaced -but nothing major. :) I'll have to measure the current coil I have.
As for reliability - I have had my mini for 6 years now - never adjusted the points, or had any issues with the original ignition (touch wood!!).
Where can I find wiring diagram for the lumenition?
#8 imack
imack
  • 2,103 posts
Posted 14 September 2019 - 07:59 PM
