I will try attaching the photo directly, here goes!
EDIT: that seems to have worked.
The spec: I will have to look out the weber jet set up, I have a note of it somewhere. Will post here soon.
Yes that's better! And yes it looks very nice not that I'm biased (I approve of the matching red shiny bits)
Thanks, that's really appreciated. One thing I have just got and need to plumb in is a fuel pressure regulator that I'm going to set at 3.5 PSI. The fuel pump I've got outputs 6.5-7 PSI so this may also be a source of some of my issues.
Thanks again.
Here is the engine spec:
1275 A series bored +40
MiniSport 7 port head
Inlets 37mm
Exhausts 31mm
Plugs NGKPMR7A
Roller tip rockers 1.5 ratio
Camshaft – Piper 285
Vernier twin row timing gear
Maniflow large bore LCB
Twin 40DCOE Webers
very short trumpets
pump jet 35
emulsion tube f11
main jet 115
idle jet 45 f9
air corrector 200
On the rolling road it made 105BHP at the road wheels (flywheel BHP ???).
It's very tractable, pulls away from 30MPH in top gear (on a 3.4 diff).
Brilliant! Thank you very much for that. It's really appreciated!
Do you know what size chokes you are running. I'm running 30's.
I've got the AKM 7 port head. Which Minisport bought the rights to so basically I've got the same head. I run a Swiftune SW10 cam which upon checking the specs is very similar to the Piper 285.
I'm not far off what you are at. I'm running 115 main jets and 45f9 idle jets although I'm running f16 emulsion tubes but I do have a set of f11 emulsion tubes.
105bhp is a nice amount. I found the 7 port head will allow you to run a wilder cam and tame the low end down so it doesn't surprise me that yours is very tractable, mine pulls well from low down which is always nice.
Who did you use for the rolling road/setup of the carbs? I really should get my backside across and get the webers tweaked by an olde pro.
Thanks again.
Edited by Orange-Phantom, 14 September 2019 - 05:35 PM.
