Clutch Drag When Warm
1 reply to this topic
#1 Zach P-D
Zach P-D
  • 444 posts
Posted 31 August 2019 - 02:55 PM
Hi all,
Recently completed an engine swap from a 1275 spi to a built  metro 1275 bored to 1310 with a HIF44 on it and all the goodies.
all is well, runs flawlessly but, when it's warm it is hard to get into gear and when idling will drag a little.
Clutch slave is a pre verto as thats what I was told worked best, and has full range of movement.
am at a loss as to why it doesn't fully disengage when hot.
tia
#2 unburntfuelinthemorning
  • 1,982 posts
Posted 31 August 2019 - 09:31 PM
There's plenty that can be wrong with the clutch.  Clutch drag is often due to a build up of many different problems from the pedal right through to the clutch plate.
Have a look at these articles from Minimania:
https://www.minimani...Pre_Verto__1086
https://www.minimani...FAQ__non_Verto_
