Top Of The Door Leaks With A Gap Between The Window Frame And Seal
3 replies to this topic
#1 Moliver8
Moliver8
    Just On Tickover
  • 5 posts
Posted 26 August 2019 - 12:19 PM
I have found that the driver door on my Mini leaks through the top between the window frame and door seal, by using a hose pipe. There is very little contact with the seal and the window frame but the rest of the door (below the wing mirror)compresses it tightly and has no issue. I have tried adjusting the hinges but it has made no difference. Not sure what I can do, can anyone help?
#2 Cabby
Cabby
  • 45 posts
Posted 26 August 2019 - 12:57 PM
try tapping the seam out slightly on the door aperture until the rubber seal makes contact with the door frame.
#3 DeadSquare
DeadSquare
  • 3,089 posts
You have got a genuine Mini.
#4 Moliver8
Moliver8
    Just On Tickover
  • 5 posts
Posted 26 August 2019 - 03:54 PM
Thanks Cabby, I'll try tapping out the seams next.
