Air Con
Posted 25 August 2019 - 11:32 AM
Posted 25 August 2019 - 03:44 PM
Posted 25 August 2019 - 05:02 PM
As already mentioned, suddenly not working probably means something else has gone. It happens. Parts are more easily sourced from Japan for AC parts.
There’s a couple of good Facebook groups for Japanese Mini owners, I help run one of them; JDM Classic Mini Owners Club
The other is Classic Minis Japan New & Used Parts; run by a chap called David Ainley
Posted 26 August 2019 - 04:29 AM
Posted 26 August 2019 - 06:19 AM
Difficult to diagnose from here but it sounds like it’s either your switch/blower set or potentially the Thermostat. The AC Thermostat is a common thing to break (an age thing). The AC Register is also a common failure point on Minis of this age.
Both the Thermostat and Register can be replaced without removing the dash.
Posted 26 August 2019 - 02:40 PM
Posted 26 August 2019 - 09:46 PM
As Pops said, the thermostat is usually the problem. It's behind the passenger dash pocket. I have replaced them in 3 JSpec Minis.
Posted 27 August 2019 - 05:28 AM
My air con works well ... a little too well at times which has made me question whether the thermostat might need replacing, where did you source them?
Posted 27 August 2019 - 03:16 PM
You can only get them in Japan. David Ainley who runs the "Classic Minis Japan New & Used Parts" Facebook page can help you
Posted 01 July 2024 - 01:28 PM
Did anyone solve this issue as mine is doing the same as above - and I've just changed the switch and the compressor, what's the register thing?
Posted 02 July 2024 - 09:15 AM
Did whoever regassed it not test it?
