I am looking to find out if GPS speedometer's are legal in the UK, i have looked online but there does not seem to be a definitive answer.
Posted 23 August 2019 - 01:23 PM
Posted 23 August 2019 - 01:36 PM
I was told, 4/5 years ago, that at that date there was no specific rule, but if a speedometer is fitted as part of the original equipment (tractors & Quad bikes for instance, weren't ), the speedometer or its replacement, had to be accurate at 30 MPH, or within 10% at other speeds.
As the radius of tyres is not a constant. a GPS is probably the most accurate speedometer available.
Posted 23 August 2019 - 03:40 PM
Ive thought about this, but does GPS take into account gradients. Since driving up/down a hill would effectivly be a longer distance than driving in a flat plane as seen from above. Therefore a speed seen by an observer above would be slower than actuall speed at the tyres.
Posted 23 August 2019 - 03:47 PM
That is why the Gps is always in touch with at least 3 satellites, because if there are 3 or more in contact, the altitude can be calculated, which means that the position of the speedometer is known in 3 dimensions.
Posted 23 August 2019 - 06:34 PM
Posted 23 August 2019 - 08:15 PM
There are some dual driven speedos available that work on both GPS and also a take off from the vehicle. I think most of these default to the GPS, but if that's not available, say, around tall buildings, tunnels, trees etc, then if falls back on the vehicle take off.
I'd doubt they are legal for some of the reasons I've touched on, in that they can drop out and they can be slow to up date too in some conditions, ie, heavy cloud.
Also, I'm not up to speed with UK Laws, but as there's no Odometer, just on that basis alone, they are not legal here. Perhaps, if other wise legal, a separate Odometer can be fitted?
Posted 24 August 2019 - 04:10 AM
I believe they do have odometers, I have a friend with one in his Moke, I'll ask him.....
Edit: My friend says his Smith's GPS speedo does in fact have an odometer.
Edited by Magneto, 24 August 2019 - 04:49 AM.
Posted 24 August 2019 - 08:16 AM
I wish somebody made a 4"/100mm GPS speedometer to replace the Smiths and which match their rev counter; the largest seems to be 80mm.
Edited by DeadSquare, 28 August 2019 - 06:23 AM.
Posted 24 August 2019 - 09:35 PM
Posted 25 August 2019 - 09:01 AM
Posted 25 August 2019 - 09:46 AM
As the engine is in the back of my Mini derivative, the speedo drive doesn't like negotiating two 180 degree bends.
I believe that Halda used to make a device, which somehow took the drive from the front wheel of a rear wheel drive, because this overcame the problem of wheel spin in slippery conditions.
Posted 25 August 2019 - 05:40 PM
Find an electronic one, that uses a Hall Effect pick up on the gearbox. They really super easy to install and wire up (even I can do it), easy to calibrate, (many have a self calibration facility now) and easy to re-calibrate with wheel and find drive changes too. Having run with a few of these now, I'd never go back to a Cable Driven Speedo.
Posted 26 August 2019 - 07:20 AM
smiths do make one via Cai Gauges/GPS speedos. I’ve got one in my pickup.I wish somebody made a 4"/100mm GPS speedometer to replace the Smiths and match their rev counter; they're largest seems to be 80mm.
Posted 26 August 2019 - 08:51 AM
Thank you.
I wonder why these haven't shown up in my searches.
