1275 Gt Brakes
18 replies to this topic
#1 Indigo
Indigo
  • 51 posts
Posted 22 August 2019 - 10:43 AM
Was the 1275GT with single line, 8.4 inch disks (& 11/16 rear wheel cylinders) fitted with a brake regulator valve at the rear?
If so, which one?
#2 Chris1275gt
Chris1275gt
  • 938 posts
Posted 22 August 2019 - 01:26 PM
Hi
I'm almost sure the 74/75 don't have a regulator. my 1975 1275gt doesn't have one and the brakes work perfectly fine. I think the smaller rear cylinders were to compensate for it not having one fitted.
#3 Spider
  • 14,836 posts
Posted 22 August 2019 - 06:40 PM
I'd need to check on fiche but from 74 to 76 from Chassis No. 19415 to 21596A one listing I have shows they had a 211774 Regulator and 11/16 RWC.
The 76 to 77 from Chassis No 21770A on have no Regulator and 1/2" RWC.
#4 Indigo
Indigo
  • 51 posts
Posted 23 August 2019 - 08:17 AM
Spider, I am interested to see what you can confirm if you can check the old fiche.
As I would like to configure them as per factory as a starting point.
#5 Spider
  • 14,836 posts
Posted 23 August 2019 - 08:16 PM
OK sure, just give me about a week, I've a bit on my plate just at the moment !
#6 Rorf
Rorf
  • 866 posts
Posted 24 August 2019 - 05:31 AM
Also depends on what master cylinder you are currently using.
#7 Indigo
Indigo
  • 51 posts
Posted 24 August 2019 - 12:39 PM
The master cylinder is 0.7 inch.  Is this corrrect for the 1275GT single line system?
#8 carbon
carbon
  • 2,590 posts
Posted 24 August 2019 - 04:57 PM
0.7 inch bore master cylinder and 11/16 inch bore rear cylinders will need a pressure regulator on the rear brakes to prevent the rear wheels locking up under hard braking.
#9 Chris1275gt
Chris1275gt
  • 938 posts
Posted 29 August 2019 - 09:08 PM
According to Somerford minis brake diagrams the 1275gt from 74/75 had 8.4 discs 11/16th rear cylinders and no regulator all other non 1275gt minis had the regulator.
#10 Indigo
Indigo
  • 51 posts
Posted 30 August 2019 - 08:26 AM
Guys, Thanks for the info.
I will try it without the regulator, as this sounds like the standard setup.
If the rears lock up under heavy breaking or in the wet, I will fit the regulator.
Bit of a pain through, as some of the brake lines will need to be changed from single flare to double (or visa-versa) to change from a T to a regulator.
#11 Spider
  • 14,836 posts
Posted 30 August 2019 - 08:40 AM
I did start looking at the fiche today, it will take some time as to piece the whole lot together, it's over several pages and some of the chassis numbers are a little hard to read.
None the less, I can confirm there was a long running series of 1275 GT with Single Circuit Hydraulics, 8.4" Discs and a Regulator Valve.
Those without the Regulator were only short lived as not too long after that, the Tandem Circuit came in.
#12 carbon
carbon
  • 2,590 posts
Posted 30 August 2019 - 06:35 PM
I hope you have got quick reactions.
If your rear brakes lock up in the wet under heavy braking a Mini can spin very quickly, and the results can be messy.
#13 Spider
  • 14,836 posts
Posted 31 August 2019 - 07:40 AM
Just had some time to sort through it almost !
From Car S20D101 to 19415A  Single Circuit, 7.5" Servo Assisted Discs, 5/8" Rear Wheel Cylinders, WL600041 Regulating Valve
From Car 19416A to 21569A  Single Circuit, 8.4" Discs (no servo), 11/16" Rear Wheel Cylinders, WL600041 Regulating Valve
From Car 21570A to ?????  Single Circuit, 8.4" Discs (no servo), 1/2" Rear Wheel Cylinders, No Regulating Valve
#14 richmondclassicsnorthwales
  • 942 posts
Posted 31 August 2019 - 09:03 AM
Very good information !
#15 Chris1275gt
Chris1275gt
  • 938 posts
Posted 31 August 2019 - 11:28 AM
Hi Moke
I've found a flow chart on Minispares website that has conflicting info with regard to the car from 21570A to ? They state a Single circuit, 8.4 discs (no servo) 1/2Rear cylinders , with a 21a1774 regulating valve. I have a single line no servo 1975 1275gt 24935a and wish to know are you or Minispares right as I want to put the correct set up on my car.
