Main Bearing Oil Way
engine
24 replies to this topic
#1 super6al
super6al
  • 79 posts
Posted 20 August 2019 - 09:13 PM
Hi everyone
After several months inactivity, I'm starting my 1275 A+ rebuild, starting with cleaning the oil ways. So question is - does the 3rd (rear) main bearing oil way drilling go straight through to the main oil gallery?
I've checked 1 & 2 with a length of mig wire & if I poke the wire from the main bearing housing I can see the wire in the main gallery, however on the 3rd oil way the wire seems to stop about an inch before the gallery. If I use an air line I can feel air coming out through the gallery.
Alan
Attached File  DCP_3844.jpg   87.94K   11 downloads
#2 unburntfuelinthemorning
  • 1,976 posts
Posted 20 August 2019 - 10:22 PM
All the main bearing journals are supplied with oil from the main oil gallery.
#3 DeadSquare
DeadSquare
  • 3,080 posts
Posted 20 August 2019 - 10:37 PM
Don't forget that at that end of the gallery, the dumbell shaped pressure relief valve seat may be obscuring the view.
#4 Spider
  • 14,742 posts
Posted 21 August 2019 - 12:25 AM
Yes, this crosses over the Main Gallery.
You really should pull the Oil Pressure Relief Valve Seat out in in case so you can clean the galleries properly, there's like some sheep of cows hiding in there!
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 21 August 2019 - 02:30 PM
This might help
#6 super6al
super6al
  • 79 posts
Posted 21 August 2019 - 02:34 PM
Thanks everyone,
I had a look & also found a photo on the forum of a cut away section of block that shows it clearly.
I tried to remove the valve seat today without success - don't really want to tap & screw it if possible.
Alan
#7 super6al
super6al
  • 79 posts
Posted 21 August 2019 - 02:36 PM
Just seen the above before i posted - Haha thats the very photo !!
#8 RooBoonix
RooBoonix
  • 1,224 posts
Posted 21 August 2019 - 07:30 PM
Thanks everyone,
Alan
Why not? They're cheap enough to replace, which whilst you're there is worth doing, along with the plunger
#9 Spider
  • 14,742 posts
Posted 21 August 2019 - 07:36 PM
Alan
They are in VERY tight so that the Oil Pressure doesn't displace it.
The only way I've ever been able to get them out is to tap them - I find a 3/8" UNC Tap does the job, and a Head Stud screwed in to that.
#10 DeadSquare
DeadSquare
  • 3,080 posts
Posted 21 August 2019 - 08:18 PM
If it isn't bust........................... DON'T FIX IT.
Any swarf that might have been in there has been washed out years ago.
If you really really feel that you must do something, steam clean the oil ways, but if you haven't got a steam cleaner, pour paraffin through the block and blow it out with an air line
#11 super6al
super6al
  • 79 posts
Posted 21 August 2019 - 09:41 PM
Main reason not to remove the seat is I don't have a suitable tap!
I've washed the block 3 times & had WD40 down there & blasted with the air line. Nothing came out, however I take the point there maybe swarf trapped behind the seat.
I bought a new valve as the old one was scored.
I've ordered some cleaning brushes, so will see if anything comes out with those.
#12 DeadSquare
DeadSquare
  • 3,080 posts
Posted 22 August 2019 - 05:54 AM
1)  Has your crank been so badly scored, that you need all this cleaning ?
2)  Was the oil pump very badly scored ?
3)  How much foreign material did you get out of the other galleries when you cleaned them ?
An advantage of the replaceable filter element is that a warning of damage can sometimes be gleaned from examination of anything that might be in the bottom of the bowl.
#13 Spider
  • 14,742 posts
Posted 22 August 2019 - 06:02 AM
Just to go the other way, I wouldn't do a build without pulling the seat. If you look carefully at the cut away photo that Retro kindly posted up, you can see there's a lot of 'dead' area around the seat and often, there's all kinds of crud and half the dead sea residing in there.
You can leave it and run the gauntlet but if you do pull it out, then you can see and you'll know for sure.
#14 Rorf
Rorf
  • 866 posts
Posted 22 August 2019 - 06:11 AM
I was under the impression that the oil pressure relief valve was before the oil filter and so any debris, swarf that might be hidden there would be prevented from going in to bearing journals.
The major side effect though could be the oil pressure relief valve shuttle cup being prevented from closing properly due to the swarf, but judging by the score marks usually seen on this shuttle, the swarf probably is forced through and back into the gearbox anyway.
#15 DeadSquare
DeadSquare
  • 3,080 posts
Posted 22 August 2019 - 06:12 AM
You are correct.
The lurking 1/2 of "The Dead Sea" has either been there since manufacture, or by-passed a blocked oil filter.
Edited by DeadSquare, 22 August 2019 - 06:24 AM.
