Granville Black Rtv Silicone Sealant
Posted 15 August 2019 - 06:52 AM
Posted 15 August 2019 - 07:07 AM
id imagine itd do the job, but wouldn't like the possibility of bits of silicone going into the valves, and compression chamber, just my thought,
Can you not use the standard gasket?
Posted 15 August 2019 - 07:35 AM
Sealing for Oil and Fuels is usually a special property and one that would usually be high lighted if it were. I'd suggest it isn't.
Posted 15 August 2019 - 08:12 AM
I know it's used for sealing in between the block and gear box. Still got a fuel leak between my Weber and supercharger and I have an MOT on Saturday. I'm waiting for some sikaflex 221 to arrive but it may not get to me in timeSealing for Oil and Fuels is usually a special property and one that would usually be high lighted if it were. I'd suggest it isn't.
Posted 15 August 2019 - 08:29 AM
Faces must be clean and flat. I always use a new gasket and smear a bit of grease on each side - the theory being as you tighten the mating faces together the grease allows the gasket to settle into place evenly.
Posted 15 August 2019 - 08:33 AM
Posted 15 August 2019 - 08:40 AM
should not be needed with the O rings and Thackery washers.
Posted 15 August 2019 - 09:01 AM
Posted 15 August 2019 - 10:31 AM
Refitted with misab plates now
Posted 15 August 2019 - 12:02 PM
I would like to use those, the alignment is slightly out, so the bolt holes on the carb have been milled out to fit the flange welded to the charger. There might not be enough meat those o ring gasket things to enlarge the bolt holes
Edited by HUBBA.HUBBA, 15 August 2019 - 12:04 PM.
Posted 15 August 2019 - 12:05 PM
is yours a vmax kit? And if so were the holes on your carb opened out a bit?I got rid of the sikaflex on my charger as when I took it apart there was a lot that had squeezed out and was blocking one of the pump jets
Edited by HUBBA.HUBBA, 15 August 2019 - 12:06 PM.
Posted 15 August 2019 - 12:14 PM
I've ordered them now. For the sake of £8 its worth a punt. The sikaflex has arrived today, so I'll whack that on for the mot and when the Misab plates arrive, I'll swap them over.If it’s between the carb and SC what about Misab Plates??
https://www.demon-tw...cB&gclsrc=aw.ds
Edited by HUBBA.HUBBA, 15 August 2019 - 12:15 PM.
Posted 15 August 2019 - 01:18 PM
On my old RS2000 running twin 45’s I swapped from O rings to Misab and the difference was light and day. Yes Thackeray washers when set correctly should prevent leaks but I had constant problems.
