Bilt Hamber Electrox Drying Time?
3 replies to this topic
#1 Bobbins
Bobbins
  • 1,486 posts
Posted 13 August 2019 - 11:15 AM
Their website says:
"Over coating can be carried out once film is hard dried – but high solvency top coats should be applied after 24 hrs"
Their PDF product download says:
"Over coating can be carried out once film is hard dried as described above – but high solvency top coats should only be applied after 96 hrs"
How long is the "usual" drying time before over coating? I'm intending to use an epoxy primer prior to the colour and leaving it a day or two is fine but if I leave it 4 days before priming I'll never get the job done!
Stu.
#2 MikeRotherham
MikeRotherham
  • 976 posts
Posted 15 August 2019 - 04:38 PM
I've had an email conversation with Bilt Hamber about this.
Drying time is dependent on what you are putting over the top. It was Gravitex that i was applying with a brush on this occasion and I waited the full 4 days although I agree it is a pain.
I've since done spraying with rattle cans a few times after leaving it only 24 hours and it was fine.
#3 Bobbins
Bobbins
  • 1,486 posts
Posted 15 August 2019 - 06:35 PM
Thanks, that’s good information. I don’t tend to rush things and fine leaving 24 - 48 hours, but 96 seamed a little excessive! I suspect the fragility of the zinc layer would mean anything being brush applied particularly something as thick as Gravitex would probably need the extended drying time.
#4 Dusky
Dusky
  • 5,322 posts
Posted 22 August 2019 - 10:49 AM
An epoxy isnt high in solvents normaly.
Although I'd leave it as long as possible to avoid solvent pop.
