I have a Clarke 150, it's probably 10 years old but works great. Get proper gas and make sure you have the right wire thicknesses. If you weld at higher amps with 0.6mm it will be a poor weld as the high wire feed speed is inconsistent, you need to have 0.8mm for the thicker stuff. I only use 0.8 for every thickness.
Mig Welder
Kevinmini
, Aug 01 2019 03:17 PM
15 replies to this topic
