Non-Starting 1275
engine electrical
22 replies to this topic
#16 mikal
mikal
  • 240 posts
Posted 25 July 2019 - 11:16 AM
"Taste it... soak your finger with the fuel, then touch your tongue and wait a couple of seconds... If your tongue stings like a hot curry your fuel is ok
.. If your tongue doesn't sting the fuel is off, best drained and replaced with fresh"
If only I'd known that when I was a refinery Chemist my job would have been easier :lol:
You are joking right?! :D
#17 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 25 July 2019 - 11:35 AM
<p>
I'm actually serious here, yes once the fuel is tasted one will need to rinse the mouth but it's all good.
I've had 3 cases of bad fuel from both supermarkets and expensive fuel suppliers, there is usually excessive moisture in the tanks at the stations.
My test will take less than 5 seconds, unlike the few minutes needed for the other tests highlighted
#18 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 25 July 2019 - 01:48 PM
It may only take seconds as opposed to minutes but who is in that much of a hurry? As a chemical biologist I can only agree on what a monumentally bad idea this is.
#19 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 25 July 2019 - 04:32 PM
Warning
Please be careful when answering peoples technical questions that you do not misguide them into taking inappropriate action. Not only is this annoying, but it can also be costly and could even be dangerous if the wrong information is given.
Some comments on here are damn right dangerous. Please note the warning above that was taken from the problems, questions and technical sub forum.
I know its hot gents but really .....................
#20 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 26 July 2019 - 08:18 PM
A bad idea? So how do we siphon a mini tank again? My method above certainly isn't dangerous. I've done it for years and I'm still here.....
#21 Dusky
Dusky
  • 5,322 posts
Posted 26 July 2019 - 10:28 PM
With one of those 5£ handheld plastic pumps, Dunn.
I love it when people use "I'm still here" as an argument. I've jumped in front of a moving train, and I'm still here too. Not something that's the best idea, is it?
I do wonder, how do you think the small amounts of fuel you're ingesting ever leave your body?
Oh and https://cfpub.epa.go....cfm?deid=36176
#22 cal844
cal844
  • 9,610 posts
  • Local Club: TFMOC
Posted 27 July 2019 - 11:54 AM
We siphon using a hose, creating a vacuum to get the fuel moving, done correctly no fuel enters the body.
When i test fuel by wetting a finger with fuel, it isn't even 5ml that's placed on the tongue, then i wash out my mouth... no harm done at all. I will agree to disagree on this. Let's get the topic back on track.
#23 Dusky
Dusky
  • 5,322 posts
Posted 27 July 2019 - 12:26 PM
You're inhaling fuel vapors that way, lots of them. 5£ is loads cheaper and easier than expensive hospital costs.
Even if it's only 0,5 ML that goes into your stomach in the end, where do you think it goes or what happens with it?
Also tagged with one or more of these keywords: engine, electrical
