I had to fabricate an adjuster for it out of scrap ali checker plate.
Posted 30 January 2020 - 12:25 AM
Posted 30 January 2020 - 08:23 AM
Working alone with only one good arm does have its challenges at times. The torque required to remove or tighten the crankshaft nut was a bit of a challenge when I had two good arms, but by bolting a piece of angle iron to the water pump bolt holes it made the job easy.
Posted 28 July 2020 - 11:19 AM
This is a flange that I made to mount my Mikuni carbouretor to the Metro inlet manifold.
Edited by Ricewind, 28 July 2020 - 11:22 AM.
Posted 28 July 2020 - 03:46 PM
Added two posts to hold the next flange to hold it all together.
Posted 28 July 2020 - 03:50 PM
Posted 28 July 2020 - 04:01 PM
And that flange needed adapting to take the tube that goes to the air filter.
Posted 28 July 2020 - 04:10 PM
The tube has a 180 degree bend that came off of a rover V8 intake. Holding it up to the old engine to make sure it will all fit nicley.
Edited by Ricewind, 28 July 2020 - 04:20 PM.
Posted 28 July 2020 - 04:25 PM
And now to make it stay there in an easily removable way.
Posted 28 July 2020 - 04:28 PM
The next job was to remove the old engine to make way for the new... eventually.
Edited by Ricewind, 28 July 2020 - 04:29 PM.
Posted 28 July 2020 - 04:44 PM
But first I had to drop the front subframe, which needs a good clean up and a lick of paint.
Posted 28 July 2020 - 09:10 PM
The next thing was to remove those pesky springs. The suspension cone strut (trumpet) has managed to attach itself to the rubber doughnut like a limpet on steroids. Getting them out without parting them is not a proposition that I want to take on again.
Posted 28 July 2020 - 09:15 PM
Cutting rubber is a lot harder than you would think so i cut the aluminium trumpet in order to turn the doughnut in order to winkle them out.
Posted 29 July 2020 - 06:11 AM
Are you intending to keep the donuts then?
Posted 02 August 2020 - 03:16 PM
No I think they have seen better days.
Posted 02 August 2020 - 03:49 PM
I was going to get this shot blasted but decided that I neede the exercise.
Edited by Ricewind, 02 August 2020 - 03:49 PM.
