Raptor Tintable Bed Liner
9 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 07 July 2019 - 06:50 PM
Hi all real quick one, will 4ltrs of raptor cover the complete underside of a mini, floor pan, boot and inner wheel arches
#2 KTS
KTS
  • 2,421 posts
Posted 07 July 2019 - 07:00 PM
Ben did the bottom of my pickup + the load bed with raptor, and i think that was a 4 litre pack he used, but not the tintable stuff
http://www.theminifo...17#entry3602452
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 July 2019 - 07:54 PM
I would say easily!
One coat is all you need and it only needs to go on lightly
#4 leepol83
leepol83
  • 1,744 posts
Posted 07 July 2019 - 08:02 PM
Brilliant thank you!! ?
Got sucked into that project thread now ha ha!
Ben-O WOW! Top work there ?
#5 geachy87
geachy87
  • Just Joined
  • 48 posts
Posted 08 July 2019 - 09:36 AM
I did mine in tintable raptor, not sure if it was just because it was white but it doesn’t seem to cover as well as the standard black stuff. I used the raptor grey epoxy primer first and this still showed through a bit after the first coat. I Had to do two coats on mine and used the full 4 litres but it looked good in the end
#6 leepol83
leepol83
  • 1,744 posts
Posted 08 July 2019 - 04:39 PM
Super I have 4 litres so more than happy to use it all, just didn’t want to run out as not sure how long you can leave it before going over it again
#7 Compdoc
Compdoc
  • 609 posts
Posted 08 July 2019 - 08:31 PM
The problem that I had with my first litre bottle was that when you pour the colour and the hardener into the bottle, as per the instructions, its practically full, and being thick, (the paint as well as the painter),it's difficult to mix correctly. The other three bottles I poured into a can, one at a time, mixed it , then poured it back into the Raptor bottle to spray. Much better result.
#8 leepol83
leepol83
  • 1,744 posts
Posted 09 July 2019 - 09:59 PM
Brilliant thanks great tip!
If I do run out ime assuming I can just buy some more and go back over it maybe a week or so later ? Or do you have a set time this need to be done ?
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 July 2019 - 11:28 AM
It cures quickly and goes off hard so I would not recommend overcoating a week later without prepping what is there first.
All you would need to do is thoroughly scuff up the cured raptor with a red scotchbrite and then you would be good to go
Ben
#10 leepol83
leepol83
  • 1,744 posts
Posted 10 July 2019 - 06:10 PM
Thanks Ben
