Turbo Fuel Pump
15 replies to this topic
#1 Chris.Williams
Chris.Williams
  • 679 posts
Posted 26 June 2019 - 07:31 PM
Hi guys and girls, just checking......even though it looks very obvious, will this work within a turbo setup?
GT1752 turbo 1275
https://rover.ebay.c...tm/312543855846
#2 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 26 June 2019 - 08:20 PM
Yep !
Phil.
#3 Ethel
  • 25,920 posts
Posted 26 June 2019 - 10:40 PM
You can probably find cheaper. Any continuous pump that betters your intended boost by 5+ psi should do. One with threaded connections might also be easier to plumb in than the 10mm hose inlet of the Metro original
#4 Chris.Williams
Chris.Williams
  • 679 posts
Posted 26 June 2019 - 11:55 PM
[quote name="Ethel" post="3604721" timestamp="1561588839" One with threaded connections might also be easier to plumb in than the 10mm hose inlet of the Metro original[/quote]
Ah yes that would make life easier.
More digging is required me thinks
#5 mini13
mini13
  • 3,810 posts
Posted 27 June 2019 - 07:52 AM
for the record any proper injection pump ( ie will do 3 bar+) will be fine.
its worth considering using the MPI tank with the internal pump as this makes a neat job of the boot.
#6 Chris.Williams
Chris.Williams
  • 679 posts
Posted 27 June 2019 - 11:03 AM
Yes considering the entire tank, little thin on the ground the old mpi minis here in nz.
I’d have to buy it all new and bring in from minispares.
#7 Yoda74
Yoda74
  • 58 posts
Posted 05 May 2020 - 12:46 PM
Sorry to Hijack your thread, but will this fuelpump do for a MG Metro Turbo Mini ?
https://www.autospor...cet-benzinepomp
Cheers,
#8 mini13
mini13
  • 3,810 posts
Posted 05 May 2020 - 04:28 PM
No, you need an injection one, as it needs to be able to provide boost pressure plus 4psi. the regulator is set to 3-4 psi, and is then fed with boost pressure raising the fuel pressure as the boost rises.
something like this for an external pump
https://www.autospor...nepomp-type-044
#9 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 05 May 2020 - 06:12 PM
Or this one. https://www.turbo-mi...om/accessories/
Phil.
#10 Yoda74
Yoda74
  • 58 posts
Posted 06 May 2020 - 10:59 AM
Thanks for your advice guys.
Why an injections pump? The Facet race/competition pump provides 5-7psi ?
@ Turbo Phil: Is turbo-mini.com your own site?
If so, what make is the pump, is it reliable and witch diameter are the hose-conectors?
Harold
#11 mini13
mini13
  • 3,810 posts
Posted 06 May 2020 - 11:11 AM
You need to Google how boost referenced fuel regulators work
#12 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 07 May 2020 - 07:12 AM
Harold
You need higher pressure because of the boost. Atleast 3 psi plus whatever boost you want to run. Ie 14 psi minimum really
#13 Yoda74
Yoda74
  • 58 posts
Posted 08 May 2020 - 01:52 PM
Is a much higher pressure a problem? All the pumps for Injection I see are 3bar (44psi) or higher.
https://www.raceware...ie-motoren.html
#14 Ethel
  • 25,920 posts
Posted 08 May 2020 - 03:22 PM
Not really, that's all that was available back when they put a T3 in the Metro. You can stick a resistor in the pump's electrical supply to drop it a bit.
#15 mini13
mini13
  • 3,810 posts
Posted 08 May 2020 - 09:43 PM
Regulator.
The regulator sets the pressure. The standard metro turbo pump if you plug the outlet will make somthing like 90 psi.
The reg sets the pressure then bypasses any extra fuel back to the pump. It works in exactly the same way as the regulation on a fuel injection system, except the regulator is set to 3-3 psi instead of 3-4 bar. It's a special regulator with a much weaker spring to allow this low setting.
