Which starter motor setup to use?
Posted 19 October 2006 - 11:31 PM
How many different starter setups are there?
Posted 19 October 2006 - 11:48 PM
What you need to find out is what age and whether A or A+ the 1275 engine is. I believe you to have an inertia on the 850. The two are not interchangeble if the 1275 is A+
If theres an extra can on the front of the starter its pre engaged.
Edited by Mini Sprocket, 19 October 2006 - 11:51 PM.
Posted 20 October 2006 - 12:06 AM
There are two starters. Pre engaged and inertia. Inertia was fitted to minis up to about 1980 when the A+ engines were introduced. There was a cross production around that time of A+ engines with both inertia and Pre engaged.
I bought an engine from England and the guy asked me which starter setup I plan to run. So if I say I am going to run a pre engaged setup I will get an A+ engine? The engine is out of a metro? Will the pre engaged starter work better than an inertia? Which should I order? Will the pre engaged starter work with the 78 wiring?
Posted 20 October 2006 - 12:20 AM
Posted 20 October 2006 - 06:34 AM
Your best bet is probably to fit the starter which was originally fitted to the engine, regardless of whether it is the same as the one on your 850, then alter the wiring to suit. This is what we've done in the past.
Posted 21 October 2006 - 10:26 AM
Posted 21 October 2006 - 09:32 PM
or just put in whatever engine u like as long as u keep the original flywheel and starter!! as long as u change the clutch there shudnt be a problem with the 1300 running on an 850 clutch!! i dont think they made them different til verto came along
Everything comes with the engine and gearbox, even plugs and air filter. The guy emailed me back and is making sure the engine I get will have the old starter, I bought the engine from LMC, they are a dealer in minis and new and used parts.
