Rover Spi Mini Cooper Fuse Box
8 replies to this topic
#1 masslaw
masslaw
  • 109 posts
  • Local Club: Victoria Mini Owners Club
Posted 19 June 2019 - 03:05 AM
I've been trying to find a diagram of the fuse box fitted to my '96 Rover SPI.  It's got 24 fuses but any of the numbering systems I have come across bear no relation to the layout of mine.  I'm not sure if this photo shows.  If it does, the third from the bottom on the left (empty) is a 15 and the silver-dotted one at the lower right is a 10.  (Both have blown)  Actually, the photo is turned to the left so you're looking at it sideways.  As I said, no numbering system I have seen give this sequence:  (Going from left to right when viewed in the car) 1-15, 2-15, 3-15, 4-15, 5-15, 6-15, 7-10, 8-15, 9-10, 10-10, 11-15, 12-10, 13- 10, 14-10, 15-20, 16-10, 17-20, 18-15, 19 -10, 20-10, 21-10, 22-10, 23-10, 24-10.
I hope I haven't made this too confusing.  The car runs fine but I went looking for a blown fuse after the radio quit and found 2 blown.  I have no idea which one deals with which in the car.
#2 GraemeC
GraemeC
  • 7,475 posts
Posted 19 June 2019 - 05:21 AM
Aren’t the 6 that are horizontal in the photo just spares?
#3 humph
humph
    How bad can it Be?
  • 1,125 posts
Posted 19 June 2019 - 07:31 AM
My 24 fuse box corresponds to this list. The numbers are moulded into the case.  As mentioned above 19-23 are for overseas spec cars or accessories.
47739012432_4e96b46ab3_b.jpgMini spi fuse list
Edited by humph, 19 June 2019 - 07:53 AM.
#4 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 19 June 2019 - 10:15 AM
I can just make out the numbers 1 - 18 in that original picture .. fuse 4 is empty.
So those fuses running in a different way could be spares. (I must add most of the Mini's I worked on had two!)
#5 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 19 June 2019 - 08:28 PM
As above the numbers are very small beside each fuse and follow the list above.
I drew the wiring diagram for this loom and you'll find it here in the first post SPi 95-96
http://www.theminifo...agrams-redrawn/
#6 GraemeC
GraemeC
  • 7,475 posts
Posted 19 June 2019 - 09:25 PM
Edited by GraemeC, 19 June 2019 - 09:26 PM.
#7 masslaw
masslaw
  • 109 posts
Posted 20 June 2019 - 02:28 AM
Thanks to everyone who helped me with this.  Now a question.  If the list says # 11 should be a 10a fuse and I have a 15a there..and #19 should be a 20a and I have a 10a..should I replace with the correct fuses?  I have not noticed any problems running this way.
#8 GraemeC
GraemeC
  • 7,475 posts
Posted 20 June 2019 - 04:58 AM
are the fuses between the rows of 6 numbered?
Edited by GraemeC, 20 June 2019 - 05:07 AM.
#9 masslaw
masslaw
  • 109 posts
Posted 20 June 2019 - 09:38 PM
Yes.  Top row: 19, 20, 21  Bottom row: 22, 23, 24.
