Overhead Valve Spring Compressor - Best
engine
22 replies to this topic
#16 hungdynasty
hungdynasty
  • 173 posts
Posted 18 June 2019 - 01:33 PM
@ nasty - that is brilliant - did you bend the scuttle (i think that's what it's called) at all ? it's pretty thin.  You should get a lot of leverage out of that, but you did it all yourself, pulling on the bar and putting the collets back in with your other hand - wow you are very coordinated !
@grizzler - that Jamal guy is the dude - I watched all his flywheel pulling videos and they were such a help - lifesaver :)
Hm...actually i put the other end of bar underarm, so I just kind of used my body weight to push the spring down and I had probably one and a half hands to work on the collets, it was not hard. And my girlfriend did take a video of my work but file is too large to upload here.
#17 DeadSquare
DeadSquare
  • 3,089 posts
Posted 21 June 2019 - 11:21 AM
I used to put extra strong (good for 7,000 RPM) valve springs on peoples Minis.
Somewhere I have a short rod on a piece of wire that fits through the spark-plug hole to hold the valve up with the piston near TDC.
My father came back from the war with some useless foreign size combination spanners;  one had a burst ring that I cut off and put an L shaped bend in, so that with the rocker pulled to one side, it slipped under the rocker shaft and the open end pressed on the valve cap.
I fished the collets out with a horse-shoe magnet and put them back, stuck with a dab of grease in the jaws of a clothes peg
It took very little longer to do valves 2 to 7 than it did to do 1 and 8.
#18 gaspen
gaspen
  • 942 posts
Posted 27 November 2024 - 07:05 PM
Just found this on Temu, maybe you interested
Attached File  Képkivágás.JPG   40.91K   3 downloads
#19 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 27 November 2024 - 08:03 PM
I was tempted, but a little concerned about putting stress risers in the valve springs.
#20 68+86auto
68+86auto
  • 900 posts
  • Local Club: Queensland Mini Car Club
Posted 29 November 2024 - 12:34 AM
I don't like that type.
I haven't found any new ones which are good.
#21 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 29 November 2024 - 09:38 AM
How would that even work?
My 40+ year old valve compressor still works even if part of the 'handle' fell off! Head off obviously. Or use the rope-trick where you stuff this down the plug holes to stop the valves moving while you work on the collets/seals.
#22 timmy850
timmy850
  • 3,330 posts
  • Local Club: MITG
Posted 29 November 2024 - 10:02 AM
You might be able to get one of these universal type compressors to work
https://sedyonline.c...l-diesel-engine
#23 68+86auto
68+86auto
  • 900 posts
Posted 29 November 2024 - 10:51 AM
They somewhat work but they restrict the amount of travel. They grab onto the spring.
