Image attached
Posted 13 June 2019 - 09:26 PM
Posted 13 June 2019 - 09:30 PM
Posted 13 June 2019 - 09:54 PM
I agree that welding in a piece of repair steel would be quickest.You can buy repair panels for the boot floor sides but to be honest some 0.9mm steel sheet cut to size is just as easy.
If I was you I would have a good look on the underside to see the full extent of the rust. There will be more.
Edited by cal844, 13 June 2019 - 09:58 PM.
Posted 13 June 2019 - 10:32 PM
I have just had to do exactly that when I found a hole in that position. However, when I started cutting it away I found that it needed more new metal than at first glance. As 'Sonikk'says, do a very thorough check of the floor.
Posted 14 June 2019 - 02:41 PM
Posted 14 June 2019 - 03:23 PM
