1997 Rover Mini 1.3I @ Mill Road Garage Isle Of Wight
235 replies to this topic
#121 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 02 October 2019 - 04:19 PM
All good. I can definitely recommend this headliner, the quality is great and it is easy to fit. It came from Optimise Automotive if anyone is interested. There are sunvisors trimmed in the same soft material to fit as well.
Ben
That's good to know, I got some samples from them for when the day comes so useful to know it's a good quality product!
Likewise, I had Optimise earmarked for headlining and their foam-backed carpet when the time comes. Lining looks good!
#122 MikeRotherham
MikeRotherham
  • 976 posts
Posted 02 October 2019 - 09:12 PM
Presumably you made the brake pipes Ben. What type of tubing with the greenish colour? They look almost look like genuine oem ones.
Edited by MikeRotherham, 02 October 2019 - 09:13 PM.
#123 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 October 2019 - 09:39 PM
Hi Mike.
They are actually the original brake pipes. All I did with them was give them a wipe over and refit them.
Ben
Edited by Ben_O, 03 October 2019 - 04:40 PM.
#124 Ben Rose
Ben Rose
  • 210 posts
Posted 03 October 2019 - 01:30 PM
I will need a headliner for mine too so its great to know.  Awesome work Ben.
#125 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 October 2019 - 11:38 AM
I have now fitted the glass
And the Cooper S works conversion had turned up
didn't know they did an A series Montego...
Ben
#126 MikeRotherham
MikeRotherham
  • 976 posts
Posted 05 October 2019 - 12:04 PM
I always thought the A series engined Montego was a bit of an oddity. I wonder what the performance was like, 1275cc lugging that body about.
#127 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 05 October 2019 - 12:39 PM
I saw this in the flesh yesterday, this is a high end build and the attention to detail is simply breathtaking.
#128 Vinay-RS
Vinay-RS
  • 2,114 posts
Posted 05 October 2019 - 02:20 PM
What does the works conversion include (in terms of trim and engine upgrades) and what are the performance gains of it?
#129 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 October 2019 - 02:31 PM
Taken from minisport website.
John Cooper conversions are renown the world over for quality and reliability. Our retro conversions are available for all Cooper models from 1997 onwards. All conversions are thoroughly tried and tested and will enhance the Mini Cooper driving experience. This engine kit increases power output to 85bhp and available as a supply and fit kit only. This kit includes larger valve, ported S stage cylinder head, high performance exhaust, improved fuelling and induction plus many more features.
Mini Road (ST3) 1275 MPI Cylinder Head - Finished in Cooper Blue
1.5:1 High lift roller tip rockers - finished in red with Cooper logo and John Cooper Signature
High Pressure Fuel Boost Valve
Maniflow LCB Exhaust Manifold - finished in Black
Maniflow Twin Silencer Side Exit Twin Upswept Exhaust system - finished in Black with Stainless Tail Finishers
K & N Cold Air Induction kit
High Power NGK Spark plugs
Aluminium Alloy Rocker Cover with Cooper Engineered Decal
Chrome Rocker Cover Cap with John Cooper signature
Chrome Rocker Cover T bars
Cooper oil cooler kit
Stainless Steel Braided Oil Cooler Pipes
Cooper Conversion Cross-member plate - uniquely numbered to your conversion
Cooper S Rear Quarter and Boot Decal supplied in either Black or White to match your Cooper.
Official Conversion Certificate - signed by Mike Cooper
Cooper Leather Key ring
John Cooper Rear Window Decal
Cooper Pin Badge
Cooper Silver Wheel Centre Cap Decals
Complete fitting kit
#130 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 06 October 2019 - 06:39 AM
That is stunning, I am embarrassed to even look at my son and I’s efforts. Well done.
#131 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 October 2019 - 03:35 PM
I have started work on the dashboard now.
The original plan was to use an aftermarket dash for this car which I have but when it came to assembling it, it was found that I would have to add provisions for the headlamp height adjuster switch and the alarm LED and there were also no provisions in the cluster fascia for the SRS lamp.
These could have been added but the main issue was the fact that you need to trim parts off of the instrument cluster which we were not keen on doing. There was also mention in the instructions about packing the cluster out to stop it rattling.
It all seemed a bit rubbish so i'm now going to modify the original walnut item.
Once I had stripped off the veneer, I had extra holes added for the AUX gauges
And then after a long session of prime - flat - prime - flat etc etc we have a beautifully smooth substrate in which to paint.
It will soon be painted silver to match the steering wheel and interior trim.
In other news, I cleaned up the engine
And then after removing the head and giving it a spruce up, I dropped it in
I had planned to fit the head but the head gasket sent with the kit had been squashed in the box and had become damaged so a replacement is being sorted out.
Ben
#132 cooperd70
cooperd70
  • 726 posts
Posted 08 October 2019 - 04:06 PM
Great work and photos Ben (as always) ?
Have never known what that line of chars (letters and numbers) on the very top of the block on the left hand side above the oil filter mean. You know Ben?
Another build to look forward to seeing completed ??
#133 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 08 October 2019 - 04:41 PM
Cheers!
The number on the engine could well be a casting number?
Other that That, I'm not sure..
Ben
#134 FlyingScot
FlyingScot
  • 2,664 posts
Posted 08 October 2019 - 05:09 PM
Yup block casting number LCF...
FS
#135 tankertanker
tankertanker
  • 53 posts
Posted 08 October 2019 - 06:22 PM
Absolutely fab totally top mini master
