Centre Speedo Wiring
4 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 02 June 2019 - 02:23 PM
Just at the point of refitting my centre speedo and I can't remember what these two green wires are for:
Everything on Google and here seems to suggest that they are for the voltage stabiliser but I already have that connected.
Any ideas?
#2 jonsharman
jonsharman
  • 71 posts
Posted 02 June 2019 - 03:49 PM
What year is the car?
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,021 posts
Posted 02 June 2019 - 04:55 PM
You should have 2 green wires going to the stabiliser, that's what mine has anyway. http://www.theminifo...-centre-speedo/
#4 luismx123
luismx123
  • 525 posts
Posted 02 June 2019 - 05:09 PM
those 2 green split off to the auxiliary gauges - temp and oil pressure I believe
#5 unburntfuelinthemorning
  • 1,976 posts
Posted 02 June 2019 - 07:59 PM
For models originally fitted with central instruments:
With a single instrument cluster there should be a single light green wire linking the L terminal on the voltage stabiliser to the fuel gauge.
With a triple instrument cluster there should be a second light green wire linking the L terminal to the water temperature gauge.
