1978 Twin Cam Pickup Build
81 replies to this topic
#76 catch_me
catch_me
  • 56 posts
Posted 19 September 2024 - 03:51 PM
Here we go!! Big update, I have finally have the 3D scanner setup (built a computer that should be a beast for CAD an anything else I need to throw at it in the future such as a driving sim in the garage down the road), and got the scanner yesterday. Ended up going the route of the Einstar Einscan so that if I want to go with a higher end scanner in the future I can do one of their professional options and not have to learn a new software.
Even after only about 30 minutes of setting it up and playing I was able to get great results on the bed side of the pickup so should be able to get a really good body scan down the road an the parts to start the CAD work and even CFD simulations in the future!
I have attached an image of what the model I was able to get thus far looks like, and hopefully will spend some time to show it in video for at some-point down the road!
#77 stuart bowes
stuart bowes
  • 2,092 posts
Posted 19 September 2024 - 05:03 PM
What sort of file do you get from the scan, is it editable vectors and points or just an image that you can use to overlay your vectors etc
Presumably you can import that into something like solidworks to fit weldments and sheet metal parts in
And if you scan it from various different angles how does it know how to line it all up right do you have to put reflective stickers on it as references or something
Always been a bit curious about how that works
Edited by stuart bowes, 19 September 2024 - 05:06 PM.
#78 Gaz66
Gaz66
  • 885 posts
Posted 19 September 2024 - 05:08 PM
All this looks like witchcraft to me đŸ˜¬
#79 catch_me
catch_me
  • 56 posts
Posted 21 September 2024 - 04:52 PM
Depends on how you export it, but it is a point cloud based file. Essentially what a scanner is doing is plotting points relative to each other in 3D space, and that is what tie file is (it connect 3 points to make triangles that give the surface).
You can import it as a surface mesh to any CAD software and use it just a mesh to design within or you can go as far to create parametric surfaces off of it using modeling software (which is what I plan on long term doing so I can run some Aero CFD simulations on things I plan to do to optimize them).
How the scanner lines things up is based on texture or markers. In this case the texture of the stripped panel was good enough but a painted surface needs markers or something for the scanner to track. I have read a cheaper alternative to markers is just putting painter's tape at various angles on panels and the scanner can track that instead of need the reflectors.
#80 catch_me
catch_me
  • 56 posts
Posted 11 February 2025 - 04:04 PM
Well just a little update, I have been slowly working on figuring out what works on small areas of the pup to scan so that I can do a complete scan of the entire body hopefully in the next few weeks! Once that happens I can get the mesh in CAD and actually start laying out some of the concepts for how to start building the new floor and things with tubing and laser cut/broke panels. Hopefully will have a cool image of the entire body in my next update!
#81 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 12 February 2025 - 03:36 PM
That's nasty
Nice lift though !
yeah its a bit of a mess honestly. The lift is working well though, my father and myself have never worked with a rotisserie before and pretty happy with how it turned out!
As an update for something to come, a current class I am taking is a computational fluid dynamics course (CFD) and the final project is analyzing a car, so the pickup may get a properly designed flat floor pan and rear diffuser designed to see if the general aero of the pickup on the underside can be improved a bit!
Watching this thread after finding it recently.  I'll be very interested in the CFD/ flat floor work
#82 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 21 February 2025 - 10:58 AM
Interesting thread this. I've seen a few images of minis with the rear subframe plated over with a sheet of aluminium, thanks for uploading the article on mini aero, I wonder if that's where they got the idea.
